Peterbilt 579 tilt slipping
Discussion in 'Ask An Owner Operator' started by GYPSY65, Aug 24, 2022.
  1. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,263
    Nov 16, 2012
    SW FLA
    I have a 579 and wondering if there’s an adjustment to tighten the tilt force when it’s locked in place
    It’s not falling down but I can get it to move with some force but don’t believe that it should and never noticed it on any of my last 3 Pete’s or my KW
  3. 062
    062 Road Train Member
    6,222
    33,477
    Oct 20, 2013
  4. GYPSY65
    1,957
    5,263
    Nov 16, 2012
    SW FLA
    Bump
    No one has any info on this number r what the fix is?
  5. 062
    6,222
    33,477
    Oct 20, 2013
  6. Goodysnap
    Goodysnap Road Train Member
    3,718
    9,033
    Jul 12, 2017
    I was digging yesterday and didn’t come up with much to help you even from TRW. We just don’t see many troubles out of this column.
    I know the tilt works off a cam style lock with a sliding disc. Maybe once u get in there it can be tightened?
    Next time we have one tore apart I will look closer.
  7. Goodysnap
    3,718
    9,033
    Jul 12, 2017
    @GYPSY65
    See attached diagram.
    I searched for COL204 and came up empty. This should be a TRW service bulletin or procedure. You can attempt to contact them directly to see if they can send it to you.
    I would remove the cotter pin from the castle nut on the tilt lever LH side and tighten one notch to see if the clamp load is sufficient to prevent movement. If not keep going one notch at a time until the lock holds and release is good.
    HTH
    AModelCat, GYPSY65 and 062 Thank this.
  8. GYPSY65
    1,957
    5,263
    Nov 16, 2012
    SW FLA
    Thanks for the info
    I hadn’t had time to pull it apart. Maybe tomorrow??
    But seems it should just be an adjustment??
    Goodysnap Thanks this.
