Peterbilt broke my truck, how much should they be responsible for?
Discussion in 'Ask An Owner Operator' started by ppaulvsk, Dec 26, 2018.
  1. ppaulvsk
    ppaulvsk Bobtail Member
    6
    4
    Dec 26, 2018
    Took my truck to a Peterbilt dealer to change my clutch. Picked up my truck and notice my speedometer was not working correctly. Took the truck back. They said they damaged the speed sensor while dropping the transmission to change the clutch. They said they would replace the sensor at no cost. In the process they said they had to change another part along with the sensor which required the Yoke to be removed. Some rotor thing. The Yoke would not come off so they had to cut it off with a torch. This also damaged the output shaft from the transmission. The truck should be ready for pickup later this afternoon.
    My question is. Should they be responsible for everything and not just the speed sensor. As in the two days of Labor the Yoke output shaft and everything else associated with it?
  3. speedyk
    speedyk Road Train Member
    1,837
    2,470
    Apr 8, 2015
    Whatever else happens, I would never go back there. They sound like stupid hacks.
    whoopNride and magoo68 Thank this.
  4. ppaulvsk
    6
    4
    Dec 26, 2018
    It all started when the mechanic didn't know how to unplug the speed sensor wire and broke the plug.
    speedyk Thanks this.
  5. Eddiec
    Eddiec Road Train Member
    2,259
    3,475
    Feb 2, 2015
    Document everything. Get every persons name and title that you talk to and when you talked to them. Every correspondence needs to be put in writing on the service paperwork or an email. All emails should include the Service manager, and the General manager of the dealership.
    Dave_in_AZ Thanks this.
  6. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    They should be resposible for all of it to me. Record everything and get it in writing that it was their fault to begin with. My uncle had to buy a guy a new 18 speed tranny because it fell off the jack and broke something and he wouldn't be able to get the parts to fix it for 2 weeks or something.
  7. AModelCat
    160,447
    I'd have to say they should eat the whole bill if its their screw up.
    Tb0n3 and Dave_in_AZ Thank this.
  8. Derailed
    Derailed Road Train Member
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    Tough situation. They are responsible for there damage but I would be real leery of having them tear any further into that transmission to fix it. What will they F up next
    Nothereoften, Dave_in_AZ and speedyk Thank this.
  9. REO6205
    REO6205 Road Train Member
    13,171
    60,501
    Feb 15, 2014
    California.
    This is an easy one...If they broke it, they should fix it. Everything, no exception.
    I agree with the guys who say to never use that shop again.
  10. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Toner ring goes behind the yoke ,don't know why it needed changing the speed sensor reads the toner ring, it's a brass ring with magnets in it evenly spaced never goes bad? Anyway best of luck to you and happy New Year
  11. 201
    201 Road Train Member
    12,431
    25,426
    Apr 16, 2014
    high plains colorado
    GET THE TRUCK OUT OF THERE!!! Who is cutting what with a torch on clutch job? I wouldn't want them to touch another thing. Find a good shop, and send the old shop the bill with your lawyers name.
