Peterbilt evaporator/heater core cleaning...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gambi80, Jul 19, 2012.
  1. Gambi80
    Gambi80 Medium Load Member
    What's a good way to get to the a/c evaporator/heater core to blow the crud out of it in a 2000 Peterbilt...??
  3. mslashbar
    mslashbar Medium Load Member
    601
    808
    Jul 22, 2009
    elizabeth,co
    It's under the glove box and behind the plastic kick plate on the passenger side. Take those out from the inside, then there'll be a metal plate held on with a few screws. Take that off and you'll see the evaporator and heater core.
  4. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,045
    May 13, 2011
    Middle Tennessee
    Better suck and not blow. A shop vac won't get the debris all over your cab.
  5. Ryanr
    Ryanr Light Load Member
    71
    14
    Mar 6, 2009
    ontario
    I just went through this with my 02 pete.I bought three cans of brake clean and sprayed the crap out of it.Make sure u do it after the truck or ac hasnt been on for a few hours so its dry.You wouldnt believe all the black sludge dust etc... that fell out of it.it dropped the temp out of vents about5-10degrees.we use to use this method when i worked at the garage all the time.and it wont smell up the cab.
