Peterbilt Sleeper clock resets constantly
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Josiah Harder, Oct 31, 2022.
  1. Josiah Harder
    Josiah Harder Light Load Member
    120
    73
    Sep 23, 2022
    The factory clock in my sleeper is constantly resetting seemingly randomly because Ive checked if turning the truck on or off causes it but it doesn't. I set the time every night and then during the day as I'm driving it must reset because it will be flashing and the time completely wrong. This is the little circular digital clock with red numbers that I think is standard with every truck. I'm about to just disconnect it if I can't use it haha
  3. Val_Caldera
    Val_Caldera Road Train Member
    2,569
    7,937
    Apr 2, 2021
    TARHEEL
    GREETINGS Josiah,
    Does the clock make any noise/s?
    If no Noise/s, just dis-co-nect.
    CHEERS!!
  4. Josiah Harder
    120
    73
    Sep 23, 2022
    It will sometimes beep during engine start up maybe that's a clue actually. I would love for it to work ideally so I can use it
  5. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,263
    Nov 16, 2012
    SW FLA
    Sounds like a loose wire that’s maybe getting wiggled enough to cause the reset or maybe a loose fuse??
    Bean Jr. Thanks this.
  6. Studebaker Hawk
    Studebaker Hawk Road Train Member
    3,012
    9,797
    Oct 18, 2010
    NW Indiana
    That's the clue. Beeps during engine startup.
    there is a voltage drop at that moment, enough to cause the clock to reset, it beeps when it does it.
    I will bet that Pete has a service bulletin on it. Either the clock is too sensitive to voltage swings or there is a wiring issue.
  7. Josiah Harder
    120
    73
    Sep 23, 2022
    I checked the connection to the clock is very secure and all the fuses seem to be good too but I just pushed on all of them to make sure
    GYPSY65 Thanks this.
  8. Josiah Harder
    120
    73
    Sep 23, 2022
    Thank you for that! It wouldn't be a battery issue would it? Because I just got brand new oddyssey batteries and the issue carried over with my new batteries too
  9. txinfl
    txinfl Bobtail Member
    5
  10. txinfl
    5
    Did you figure it out? Mine does the same thing
