I got a 96 379 and when its settin still and u steer it to the right it hits a hard spot and stops short of all the way, if your moving it's fine. It steers fine to the left, and drives very good. Just put a new power steering filter in, didn't change anything. The tie rods are good, just had alignment. Any thoughts?
peterbilt steering
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bean farms, Jan 25, 2012.
With the proper operation of the steering gearbox relying on the stability of the axle in the chassis, I would first check for axle shifting when sitting still and steering from lock to lock. I would be looking for movement at the spring shackles/spring eyes at rear of front springs. Axle shift can throw off the proper operation of the steering control valves.
I had one that had similar symptoms to this, and it ended up being the power steering pump.
I herd of a factory recall on that. That the truck didn't turn right. Non ever made it back to be fixed lol
if there was a re call rekin they would still fix it
I rekon so
That's how they first show their weakness, at idle, raise idle slightly and problem goes away.
I have a 99 379 mine started that too I replaced the filter then eventually the pump went out while I was backing into a produce dock....
how much does the pump cost how could i tell if there is a recall on the pump
If I remember right it's around $200 and some change
