Peterbilt Voltage Spikes
Discussion in 'Trucks [ Eighteen Wheelers ]' started by KittyKicker, Jan 12, 2019.
  1. KittyKicker
    KittyKicker Light Load Member
    196
    100
    Dec 27, 2015
    I have a 2007 Peterbilt 386 that keeps having voltage spikes. I replaced the alternator a few months ago for an unrelated issue. Truck was on the road for a while, no problems. One very rainy night the driver loses all of his external lights (except for the trailer lights) and his dash lights cut out, too. His 4 ways wouldn't even work and his voltmeter was pegged in the red. He shut it off, restarted it, and the voltage was fine. His lights came back one by one. He drove it 300 miles back to the yard, no further issues. I replaced the alternator anyway, thinking bad regulator. I checked his headlight harnesses and wiring, found nothing. Put a new alternator on, been working fine, no issues. Tonight (a very snowy night) the truck just did the exact same thing. I am stumped....
  3. pushbroom
    pushbroom Road Train Member
    1,779
    7,313
    Sep 1, 2012
    Lighting is controlled by the cecu. If it senses too much voltage, it will shut down.
    First check is alt cables back to the batteries, will need a voltage drop test done. Also clean all cables including cab grounds. Test the batts.
    I have had some trucks that will not work with an aftermarket alternator. Tried multiple aftermarket ones and it still overcharged. Bolted on a factory one worked perfect. Put the other aftermarket alts on a cecu truck and it also worked fine. Never found any reasoning for it.
    x1Heavy, Goodysnap, Wheeljack and 3 others Thank this.
  4. KittyKicker
    196
    100
    Dec 27, 2015
    Thanks pushbroom I will give it a shot. I checked grounds and what not the last time, but it's worth another look!
  5. Wvcoalpacker
    Wvcoalpacker Bobtail Member
    23
    8
    Dec 22, 2017
    Did you figure it out? I’m having this problem now.
  6. KittyKicker
    196
    100
    Dec 27, 2015
    We ended up running an extra ground from the alternator to the frame and never had another problem. I hope that helps.
    Wheeljack and x1Heavy Thank this.
  7. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,136
    Mar 5, 2016
    White County, Arkansas
    Now there is a idea.
    Thank you!
    KittyKicker Thanks this.
