Peterbilt vs Freighliner
Discussion in 'Ask An Owner Operator' started by RANGER68, Mar 19, 2015.
  1. RANGER68
    RANGER68 Bobtail Member
    28
    Feb 21, 2015
    Hello Ladies and Gentleman your toughs and or choice....
    Thanx
    2012 Peterbilt 386 400,000 miles
    Cummins ISX15-450ST, eng brake, Eaton Fuller 10 spd, A/R cab, Air Leaf A/R susp, 12000 lb frt, 40000 lb rears, 244 in. WB, 64 in. sleeper, alum outers, wet kit, PTO
    vs
    2011 Freighliner Cascadia 600,000 miles
    Detroit DD15 14.8 L, 560 hp, eng brake, Eaton Fuller FR15210B 10 spd, A/R cab, Air Liner susp, 12000 lb frt, MT40143 rears, 228 in. WB, 66 in. high rise sleeper, aux power unit, alum wheels, Super Singles, 2.64 gear ratio, DPF
  3. TaylorMade407
    TaylorMade407 Road Train Member
    1,328
    1,036
    Jun 30, 2009
    Orlando,FL
    Do you have to run Cali? If so try to get maintenence records on either one. Which ever has the least amount of issues. From what I'm seeing these new motors need overhauls round the 500k mark so take that into consideration. What are you hauling
    RANGER68 Thanks this.
  4. Mr.X
    Mr.X Heavy Load Member
    737
    596
    Oct 31, 2013
    Spokane, WA
    If I had to drive it, definitely the Pete, I have drove both of those trucks (Penske rentals) The 2012 Pete still feels good on the two lanes and curves, but to me the Freightliner feels like your pulling a semi trailer with a golf cart, especially in side winds.
    The older inline Detroits were like bic lighters, when the fire goes out you throw it away. Not much experience with the new ones. I am a little prejudice, but only cause every Pete I ever drove, I liked, even the old wore out ones.
    At 400k Im betting that Pete has a lot more miles left in it, and guessing the Freightliner will be on the ramps within 200k (800k seems to be their magic number).
  5. bad-luck
    bad-luck Road Train Member
    3,300
    6,066
    Nov 16, 2013
    Baltimore, Maryland
    I like to know where you are getting your information that these engines need to be rebuilt at around 500k? Im guessing the pete is priced around $50k and according to your information the truck only has around 100k miles left....
  6. uglyvegas
    uglyvegas Light Load Member
    88
    27
    Oct 5, 2011
    las vegas, nv
    normally I would go with the freight, I like how they drive better than the pete, especially the turning radius. But with the miles on the dd15 I would have to go with the pete. Have driven both and the ISX seems to be a more reliable unit. The one I'm driving now has had some problems, but nothing major and it has never left me stranded... can't say that about the dd15 I use to drive.
  7. Fajo
    Fajo The Dark Knight
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    I can agree on 800k golden mark on the ISX, around that milage they seem to like to eat a headgasket or flatten a cam. Tho with the rebuild and the revisions im told they can hold a 1 mill on the rebuild.
    (source, Cummins tech that rebuilt mine in Boise, ID.)
    Mr.X and RANGER68 Thank this.
  8. OldHasBeen
    OldHasBeen Road Train Member
    1,269
    924
    Dec 16, 2010
    The Pete, its much better truck than a Freightliner. And a Cummins is better than a Detroit.
  9. 77fib77
    77fib77 Road Train Member
    10,637
    66,966
    Jul 7, 2010
    St Louis
    Not really comparable, but I was driving a 300 k Pete in the oil field last night. It is still tight and quite.
    You need the wet kit???? Its excess weight if you don't. I assume you could make more money with it than hauling a dry van.
  10. poppapump1332
    poppapump1332 Road Train Member
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    Peterbilt with the cummins easy decision
  11. 77fib77
    10,637
    66,966
    Jul 7, 2010
    St Louis
    Whats the price difference between them?
