Peterbuilt 386 vs Prostar
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Md420, May 10, 2016.
  1. Md420
    Md420 Medium Load Member
    469
    559
    Nov 2, 2015
    Tn
    Like to stay away from opinions on the way they look and fit/finish.
    If you were to pick between say a 2011/2012 386 and prostar both with a isx both around the same milage bothe strait 10's which would you do?
  3. Sportster2000
    Sportster2000 Road Train Member
    1,480
    886
    Jan 5, 2008
    Indiana
    Peterbilt because I truly think that you can get better fuel mileage out of them and they weigh less than the Prostar.
    Md420 Thanks this.
  4. dngrous_dime
    dngrous_dime Road Train Member
    3,150
    5,765
    Jan 28, 2014
    Lansing area, MI
    Depends if you want resale value in 3-4 years, or if you just plan to run it till it's dead. Personally, I prefer Internationals, but I know the Pete will hold value better.
    Md420 Thanks this.
  5. Md420
    469
    559
    Nov 2, 2015
    Tn
    I honestly like a prostar/isx combo. I've had good luck with them, 6.5+mpg and I am familiar with them. I detest kw 660's looks but like the 386 and I know the 660 is probably the most aerodynamic truck on the road and figured the 386 got some of those traits from it's cousin.
  6. crb
    crb Road Train Member
    1,676
    1,374
    Dec 1, 2009
    USA
    Company or o/o?
    Price difference if buying?
  7. Md420
    469
    559
    Nov 2, 2015
    Tn
    Would be o/o. Price is nearly the same.
  8. Md420
    469
    559
    Nov 2, 2015
    Tn
    Here
    Prostar is a 2012 with 325k miles on it, 450hp isx, eaton fuller 10 speed. $39,000
    Pete is an 11 with 370k miles on it, 450hp isx eaton 10 speed $44,000
    Have seen a clean rig dig on both, both have regular updates on ecu history. Prostar had a new turbo at 275k
  9. solitary_con
    solitary_con Light Load Member
    147
    137
    Mar 2, 2007
    Cook County, IL
    Between the two, the Pete was a better ride. Far as fuel mileage they both did around 6.9 mpg pulling an average of 48k. A lot of cruising and minimal hills.
  10. Sipesh
    Sipesh Medium Load Member
    617
    1,101
    Apr 3, 2014
    Colorado
    If you like to work on the truck yourself, that 386 having the longer hood makes working on that Cummins engine a HECK of a lot easier. The back of the engine is accessible. Prostar has it crammed up under the cab pretty far.
  11. dngrous_dime
    3,150
    5,765
    Jan 28, 2014
    Lansing area, MI
    Apu? Bunk heater? Similar bunks? If all else is equal, I'd go with the Pete.
