Petition to the Federal Motor Carrier Safety Administration (FMCSA) Request for Revision
Discussion in 'Trucking Industry Regulations' started by GoHardTrucker, Nov 22, 2024.
  1. GoHardTrucker
    GoHardTrucker Bobtail Member
    9
    6
    Apr 2, 2024
    Georgia
    This campaign needs you now
    I’m starting a petition to gather signatures from fellow truck drivers to urge the Federal Motor Carrier Safety Administration (FMCSA) to address critical issues affecting our industry. Your support is crucial in advocating for fairer regulations and improved conditions for drivers. Please take a moment to sign and share the petition with others in the trucking community!
    silverspur Thanks this.
  3. RockinChair
    RockinChair Road Train Member
    5,118
    12,941
    Feb 19, 2012
    CC, TX
    If I'm reading this correctly, this is about correcting the way warnings count against our PSP as much as, or worse than, a ticket.
    So of course I signed it.
  4. SirLaTroy
    SirLaTroy Bobtail Member
    I feel some unfair policies with SAP regulations need addressing. I listed here a few facts I believe deserve attention.
    1 the level at which a drug is found in someones system determines probabilities of if or not a persons motor function, cognitive ability, perception, behavior etc....are being affected by substance at time of detection. That should taken into account before concluding a rate at which substance use has contributed to accidents
    2 detected levels should also be deemed important to determine levels of usage and to what extent it can be concluded a persons habitual usage has affected them long term.
    3 if the point is to keep drug impaired employees from putting saftey at risk, restrictions should only be imposed where it can be evidenced a person has been on duty while actualy impaired. Certain drug use may be illegal, but the mere fact it was found in ones system does not mean they would come on duty impaired It also doesnt mean a substance wasnt ingested unintentional.
    4 if it has been found by investigation that treatment expenses and other restrictions are recurringly being imposed with ulterior motive, a person shouldnt be prevented from knowing certain treatment plan details. For example: While not disclosing test frequency can be considered a measure to prevent users knowing when to pause using, a person not being allowed to know how long he is being required to undergo testing or restrictive/costly circumstances is not. This only enables ethical rules to be avoided. A person should have right to know if or not any restrictive obligations have been imposed fairly and in accord with actual treatment needs and ethical guidelines
    5 its contrary to procedural fairness to declare that conclusions made by fmcsa affiliated laboratories or SAP counselors cant be challenged for legitamcy or accuracy by other outside scientific institutions.
    I dont if these matters are being addressed but I believe they deserve attention as well as anything else
  5. buzzarddriver
    3,605
    10,444
    Feb 1, 2011
    Dallas, TX
    Pop hot on a UA, BANNED for life. How's that?
    wis bang and kemosabi49 Thank this.
  6. kemosabi49
    10,697
    45,959
    Jan 13, 2013
    SW Arkansas
    People know the rules when they get their CDL. Doesn't matter how much is in your system, if it is in your system and detectable, you fail the test. And drivers know a failing a test will entail if the ever want to drive again. The steps in the SAP program are clearly explained.
    .And I realize that in many states marijuana is legal for recreational use. The Dept of Transportation agencies, FMCSA, TSA and the FRA wil be required to maintain testing for workers in safety sensitive positions until the time that there is a standard developed for how much is too much, as the BAC % is for alcohol. And a DOT certified accurate and inexpensive test comes online to determine that level.
    wis bang Thanks this.
