Picking up trailer with temporary plates on the truck
Discussion in 'Ask An Owner Operator' started by Stork, Jan 10, 2022.
  1. Stork
    Stork Bobtail Member
    Jan 4, 2020
    I haven't been able to find an answer anywhere, any information is greatly appreciated.
    My company is located in Raleigh, NC.
    I have a truck that I've bought in Cleveland, OH. One of my drivers will go and pick it up. I know, that with a hunter permit, he should have no problems in getting the truck to Raleigh, NC where we will add IRP plates and the rest of the documentation needed to start hauling freight.
    But I've found a trailer that I like in OH. Can my driver pick up the trailer as well and bring them both to Raleigh NC running on temporary plates or is it so that if you pull a trailer you need to have IRP plates for the truck?
    Thank you
  3. pavrom
    pavrom Road Train Member
    3,187
    7,310
    Apr 29, 2012
    NE illinois
    If your temp plate reads 80k - you should be good
    Stork Thanks this.
  4. bad-luck
    bad-luck Road Train Member
    3,329
    6,127
    Nov 16, 2013
    Baltimore, Maryland
    I personally have never pulled a trailer with a tractor that has temporary tags. I believe that you will be ok because you are not hauling a load. HOWEVER I would check with your home state North Carolina DOT first. I am sure that you are aware that DOT fines in any state are extremely expensive. Better to be safe than sorry. Good luck.
  5. Banker
    Banker Road Train Member
    4,221
    12,772
    Aug 19, 2012
    I picked up a newly built car carrier rig tractor and trailer in 2016 in Ga and drove back to Ky with no issues from Ga, Tn or Ky. Both units had temp tags.
    Many years prior to this I drove a new to me, used road tractor with temp tag to pickup a used flatbed in Ky with temp tag to bring home in Ky. I was stopped at the first scale I crossed. He told me I couldn’t do this with a temp tag on the tractor but let me go without a ticket. You may want to call the states you will travel through.
  6. Midwest Trucker
    5,911
    21,381
    Aug 31, 2018
    Grab it and haul ###.
    Last Call and lester Thank this.
  7. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,141
    Jan 30, 2011
    Don't know about NC, but the GA IRP system gives you a pdf of the cab card soon as you pay. I'd get that, plus print out the IFTA license (also available as soon as it processes in a day), and have them on me for the trip, with nothing but posterboard signs on the doors with company name and dot number. Far as the trailer, the Maine agency I use will overnight the actual plates in two days. I wouldn't even bother with temp registrations.
    If your driver don't mind night/weekend driving, bring the rig back overnight on a weekend. The only places I seen desperate enough to have weigh stations open in the eastern half at that time is VA and KY, and not really as much lately since they have covid as another excuse not to work.
  8. super dump driver
    super dump driver Bobtail Member
    27
    24
    Oct 13, 2018
    Pretty sure you have to have registration. You would have to get title faxed or emailed to you. Dmv will issue a 7 day temporary registration with that information. At least that is how I would have to handle that situation in Colorado
  9. wis bang
    wis bang Road Train Member
    3,416
    4,049
    Jan 12, 2011
    Levittown, PA
    the 'Hunters Permit' temp covers you to bobtail around looking for another carrier who supplies IRP.
    Other states issue temps with apportioned info [the states just like an IRP reg] and are legal to haul freight..
  10. Ridgeline
    22,504
    118,519
    yes you can, as long as you are not hauling for hire, just did this Monday.
