Pitted Frame, Send It?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Hilltop Hustler, Jun 6, 2025.
  1. Hilltop Hustler
    Hilltop Hustler Light Load Member
    78
    52
    Apr 29, 2023
    West Virginia, USA
    So it appears my 378 is going through an awkward phase in its life and is crater faced. Nothing crazy it literally looks like small acne craters, no deeper than any pock marks youd seen on a teenager.
    No holes, can't stick my screw driver through it, not cracked. The truck was delivered to me without a 5th wheel and the pitting is right exactly where the fifth wheel would be. Rest of the frame is good. When I put a fifth wheel on it, it should pass a visual inspection. Is there any fixes I can preform on it?
  3. DUNE-T
    DUNE-T Road Train Member
    7,014
    17,069
    May 10, 2015
    Detroit, MI
    I get a grinder, attach a metal brush to it, clean trouble spots and paint over. Do it every summer or two
    Hilltop Hustler Thanks this.
  4. Big Road Skateboard
    6,655
    37,375
    May 2, 2021
    You could put a golve in it. I did on my Jimmy.
    Made me feel better, but that was probably all it did
    W923 and Hilltop Hustler Thank this.
  5. AModelCat
    161,302
    Doubt it's near as bad as it looks once it's cleaned up.
    Sons Hero and Hilltop Hustler Thank this.
  6. 201
    201 Road Train Member
    12,621
    25,905
    Apr 16, 2014
    high plains colorado
    Under the 5th wheel is always a bad spot, and I've seen frame rails crack under the 5th wheel. If ambitious,, I'd run a U channel inside the current frame rail under the 5th wheel,aka, double frame, kind of. Rusty frame rails are a concern, but I was told, if the top and bottom are okay, the side can get pretty rusty before failing. Coming from the Badger, almost every older truck I drove had those rust "tumors".
    Hilltop Hustler and Iamoverit Thank this.
  7. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,941
    Oct 31, 2023
    Can't say for sure without seeing it but pitted frames are very normal in the rust belt.
    Hilltop Hustler and 201 Thank this.
  8. 201
    12,621
    25,905
    Apr 16, 2014
    I've seen and driven trucks, that when the 5th wheel was removed, the frame sagged. Sometimes the 5th wheel was holding it together:eek:
    beastr123, '88K100, D.Tibbitt and 2 others Thank this.
  9. Hilltop Hustler
    78
    52
    Apr 29, 2023
    West Virginia, USA
    I think that's a feature for when you drop a trailer
    201 Thanks this.
  10. Rideandrepair
    17,432
    56,539
    Aug 8, 2015
    Usually in front of fifth wheel is where I’ve seen the Pete’s rot out. Sherwin Williams has a product called Frame Saver. Others are similar. Some stay black, some fade, but can be painted. Most can be applied with a brush, or thinned and sprayed
    . Other products available similar to the very expensive por-13 that allow leaving stable rust in place. Do some research. Lot of options. They’re all different, some combination of paint, rust converter, or epoxy paint.
  11. MRMTRANS
    MRMTRANS Medium Load Member
    392
    428
    Apr 28, 2015
    Got quite a bit of rust and pitting on my 2002 Century. This mechanic I go to, who's a real guru, told me scrape off rust, and don't paint, unless your sure the paint job won't eventually let moisture behind it. That's hard because you really got to to a good job getting all the rust off. Maybe Frame Saver works-don't really know. I've just cleaned flaky rust off every 1-2 years for the last 12 years and it really hasn't gotten much worse at all. But I live and run in the dry climate if the mountain West. If you want to keep it looking as good as new-and it lasts- you can have it professionally stripped down with a glass/ sand blaster and then paint. That mechanics son bought a underwater blaster used for ship welding, and did a resto project and it looked great throughout the job, and when it was done. He used a median that only took the rust off and didn't go into metal. Don't remember what median. That was 10-15 years ago.
