Pittsburg power ceramic coated exhaust manifold rusting
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 66truck, Jan 29, 2017.
  1. 66truck
    66truck Light Load Member
    136
    29
    Nov 7, 2008
    ohio
    I installed one of these about 4 months ago and its starting to get surface rust on it, anyone else seen this happen?​
  3. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
  4. Brandt
    Brandt Road Train Member
    4,432
    6,000
    Sep 17, 2012
    I thought they only ported and polished exhaust manifolds.
  5. Cat sdp
    Cat sdp . .
    20,821
    71,625
    Apr 8, 2012
    Orion's Belt
    I've heard the ceramic coating either burns off or whatever .....
    Got no 1st hand experance tho.
  6. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    It does, it is only applied at lower temp so when the manifold heats and the metal expands it cracks the coating and lets it flake off, any ceramic coating is a marketing ploy.
    tony97905 and Oxbow Thank this.
  7. Inthedark
    Inthedark Light Load Member
    98
    91
    Jul 12, 2016
    springfield MO
    Have a look at Cerakote, they tell you the hours it will withstand failure. Take heed, if you decide to do it; find a "certified applicator". There are many people doing this that do not follow the correct process.
  8. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Here's a trick I learned in the antique car restoration business that has worked very well for me. Plain old sliver Never-seize, it's messy so wear disposable gloves, but works. Sandblast the manifold clean, then uses a rag to smear it on, not globs, just a thin coat just enough to give it a uniform color. Install the manifold, then use a rag to smooth out what you messed up installing it. When you start the engine is will smoke like hell for 15-20 minutes, but it will stay looking like new bare cast iron for years.
    I've done it on on truck manifolds and turbo turbine housings and years later still look new. Zep makes a spray anti-seize called Groovy that work great for this too, just sprat it on and even it out with a rag.
    This also works great inside chrome pipes on hotrods and motorcycles. Uses a soft brush or cotton on a stick to get a coat 6-8" down the tubes and they will not turn blue.
  9. Brandt
    4,432
    6,000
    Sep 17, 2012
    Does Pittsburgh Power even has ceramic coated exhaust. I never heard of them and they don't show any on their website. They port and polish the exhaust manifolds
  10. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    From what i understand pitts power and bully dog all use the full tilt manifolds.
    Pitts power does not port and polish manifolds nor do they even make there own manifolds.
    The only people that do are PDI . U can get there normal manifold ceramic coated or there extrude honed manifold ceramic coated.
    Personally i run a bullydog manifold (fulltilt) on my detroit and my cat. Its ports are way better then the stock manifolds and they come ceramic coated. Never had a issue with coating rusting nor peeling off. The manifold on my cat is 6 years old still looks like the day i put it on other then its a little dull.
    My buddy put a pdi center section on his detroit and with in a year was leaking.
    Put a bullydog on now and no issues any more.
    Personally i wouldnt even buy a tooth brush from PDI.
    JimmyWells, Oxbow and snowman_w900 Thank this.
  11. Oxbow
    Oxbow Road Train Member
    12,511
    128,613
    Nov 24, 2015
    I'm confused; does the ceramic coating go on the inside to improve air flow, or on the outside to retain heat? If on the inside wouldn't it be hard on the exhaust side of the turbo if it flaked off?
