Pittsburg power max mileage
Discussion in 'Ask An Owner Operator' started by Short Fuse EOD, Jun 1, 2021.
  1. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    I just have a diesel force cleaning done every 300k and don’t idle. Biggest problem with newer engines
  3. Dino soar
    Dino soar Road Train Member
    4,809
    26,922
    Dec 8, 2017
    Snake oil...
    Stray_Dog Thanks this.
  4. TallJoe
    TallJoe Road Train Member
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    I was asking this sort of rhetorically, hoping to be positively surprised. To claim that fuel is burnt more efficiently due to some catalytic agents in the product would require an explanation as to what those agents are and how they are involved in fuel burning process to make the claim credible. Even if someone says that it works wonders for them
    jason6541, John E. and Stray_Dog Thank this.
  5. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    You should try essential oils. Karen swears that she gets 100MPG loaded, uphill.
    Stray_Dog and jason6541 Thank this.
  6. olddog_newtricks
    olddog_newtricks Medium Load Member
    639
    2,162
    Jun 3, 2018
    No , I don't have soot problems. That's why I use the snake oil . Get it clean and keep it clean. It may end up being a waste of money in the end. For now ,I think it helps so I'll keep using it.
  7. Arctic_fox
    4,372
    23,835
    Sep 16, 2016
    IIRC the main parts of PBMM are magnisium and iron (i could be mistaken here) which act as a catalyst to help break down the fuel better which can lead to a cleaner burn. In older style less efficent engines this stuff can work wonders. I remimber an old artical where antique boilers and generators responded very well to catalysts and saw massive gains.
    However, modern trucks are super efficent compared to what was avalible in the past. As such as a truck gets more efficent there is less to bond to and less positive gains. In something like an old coal roller like a 3406B series or a big cam cummins you would likely see quite noticible gains. In something like a MX13 far less so. Otherwise the EPA would be chomping at the bit to get this stuff mandatory as a standard fuel mix.
    Also keep in mind its not the soot that clogs up your EGR and such. Its the ash, so while you may produce less SOOT i.e less black smears on your trailer. And keep in mind this next part is only what i have read elsewhere and may be wrong. You may actully produce as much or more ash depending on the formula used or how your engine runs. Though in some cases you can produce less.
    So again id just pay to have the system cleaned a couple times a year. Not that expensive and you can schedule it for down time as well as have a full health check done on the system to head off problems.
    Short Fuse EOD and TallJoe Thank this.
  8. liner
    liner Medium Load Member
    476
    684
    Mar 15, 2008
    ontario
    Over priced snake oil.Did absolutely nothing for my truck.
    abyliks and LOTSO Thank this.
  9. LOTSO
    LOTSO Heavy Load Member
    833
    2,008
    Mar 28, 2023
    I had the same results.
