please help. loud grinding noise going down the road
Discussion in 'Trucks [ Eighteen Wheelers ]' started by welttruck, Nov 7, 2012.
  1. dztruck
    dztruck Light Load Member
    271
    208
    Feb 22, 2017
  3. JonJon78
    JonJon78 Road Train Member
    7,207
    42,211
    Jul 1, 2018
    What was the fix for this?
  4. Short Fuse EOD
    2,786
    8,738
    Jul 29, 2015
    Midwest
    The ride height I have now about 1/2 inch above spec on rear bags. Front bags are at spec. Seems to fix issue unless I am going 70 mph + downhill. Knocking went away a little after fuel pump was reinstalled with proper timing. Still have knocking on hard pull in higher gears around 1500-1600 rpm. Resolution- I have yet to find a shop that knows what they are doing and does warranty work. I have bout given up on issue and will ride until failure.
    JonJon78 and dztruck Thank this.
  5. dztruck
    271
    208
    Feb 22, 2017
    #### that sucks to hear. Im still having the same issue. Just a few weeks ago my driveshaft fell off completely. Was able to salvage the part and put it back on but its still making that noise. Beware my friend.
  6. Short Fuse EOD
    2,786
    8,738
    Jul 29, 2015
    Midwest
    Only the best quality control right?!
    Factory also forgot to insert all bolts to my forward universal. Darn Covid build truck!
  7. JonJon78
    7,207
    42,211
    Jul 1, 2018
    The problem I'm having is when I give it fuel the RPMs rev but it doesn't accelerate... I have to barley give it any fuel and ease into it to go anywhere. Called one shop today that claims it sounds like my clutch is bad? IDK. Going to make an appointment to have the ride height checked first and go from there...
  8. AModelCat
    161,302
    Definitely sounds like a slipping clutch.
    JonJon78 Thanks this.
  9. Short Fuse EOD
    2,786
    8,738
    Jul 29, 2015
    Midwest
    Had that happen in low gears a few times lately. Clutch inspected and adjusted 4 times!! Not very happy.I was told last week after last adjustment that the clutch is over 50 % good and no metal shavings…
