PLEASE HELP - My automatic transmission truck wont go into gear
Discussion in 'Peterbilt Forum' started by sprechnd, Apr 5, 2014.
  1. RSQ20
    RSQ20 Medium Load Member
    The X-Y is based on geometry
    Unfortunately you are displaying ignorance in the matter of Auto's
  3. EHB
    EHB Medium Load Member
    491
    209
    Apr 26, 2011
    Newfoundland
    Well they could of just called it an the automatic transmission electronic servo control module ...
    That would make a hell of alot more sence to me.
  4. Tickler
    Tickler Bobtail Member
    4
    Auto transmission in 09 Kenworth had pedal replaced & harness be its starting again when taking off from a stop pedal is dead let up than starts to go
  5. Tickler
    4
  6. CaptainDaveG
    CaptainDaveG Road Train Member
    1,478
    2,359
    Jul 31, 2014
    Fremont Wi
  7. dryriver
    dryriver Bobtail Member
    Apr 23, 2016
    2007 Peterbilt 386 with autoshift (has clutch) Moving at speeds under 30mph it would shift into neutral while flashing the "F". Nothing to do but coast to a stop, shut down the engine and wait about 20 minutes. I would then hear a click under the floorboards, start the engine and it would be fine. Might happen again in 1/2 mile or might go 500 miles before it happened again. In one instance, it made about 50 feet.
    1st mechanic: Low battery voltage then said short in tranny wiring. Replaced batteries and wiring harness to tranny.
    2nd mechanic: sure there was a short, but couldn't locate it. Cleaned all connections on ECM coated with dielectric grease and hooked back up.
    3rd mechanic said short in the XY shifter. Replaced entire shifter unit on top of tranny. Called Peterbilt to help locate short but was told you could only buy the unit complete.
    4th mechanic (after a total shut down-engine died and wouldn't start). Found the engine wiring harness across the back of the engine (bundle of about 30 wires) was smashed and wires shorted out. Replaced engine wiring harness and ECM which was fried. Now over 40K miles since last occurance and running fine with just a little over $4000 invested.
    DudleyBoyNC Thanks this.
  8. Tickler
    4
  9. Tickler
    4
    Thanks changed fuel filters & running great
  10. Xatruch04
    Xatruch04 Bobtail Member
    Mar 8, 2017
    I had the same problem, freightliner century 2007 with Eaton 10 speed smart shift. Started with code 37, changed battery to tecu power supply and tecu ground wires, cleaned battery, cables and ground terminals. Did not work, changed transmission harness, did not work. Checked all electrical components, changed xy shifter, did not work. Changed all 3 speed sensors, did not work. Finally took apart tone wheel housing behind transmission, right in front of first yoke, the tone wheel was damaged. Replaced all parts in housing, put in another new speed sensor and that solved the problem. Truck shifts great again. [GALLERY=][/GALLERY]
    2013Maxx and DudleyBoyNC Thank this.
  11. Xatruch04
    Mar 8, 2017
    2013Maxx Thanks this.
