Please help
Discussion in 'Ask An Owner Operator' started by Mdsd82, Dec 15, 2020.
  1. Mdsd82
    Mdsd82 Bobtail Member
    Dec 15, 2020
    So recently purchased an 06 freightliner Columbia (used from private owner) and am getting to lease onto a company. I'm needing to know the length, weight, and declared value of the truck. Can't find the first 2 anywhere in the cab or owners manual. Everything I've found online says these are printed on stickers on the door sides. The stickers are completely worn white can't get any info from them. How can I get this info? Declared value im hoping someone can help with a website that i can figure this out without having to pay a fee.. i know these are probably "rookie" questions but I'm having trouble finding answers via Google. Tyvm for any help u can give
    truckdriver31 Thanks this.
  3. Ruthless
    Ruthless Road Train Member
    9,007
    89,031
    Aug 28, 2010
    The City.
    Tape measure, local quarry, n how much you paid for it/what it would sell for prolly get you all the answers you want
  4. AModelCat
    160,820
    Concur with above. Tape measure and find a place with scales to get the weight. Its next to impossible for the manufacturer to list the weight of every truck since there are literally hundreds of different component combinations that will affect the weight.
    Mdsd82 and truckdriver31 Thank this.
  5. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    wheelbase is like 215" long. weight is like 17,500 lbs. declared value is what you want. say $30k. insurance will only pay the value at the time of lost.
    Mdsd82 Thanks this.
  6. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    or like above. tape measure, cat scale and value
  7. AKDoug
    AKDoug Medium Load Member
    323
    802
    Mar 21, 2018
    Does no good to go by door sticker or registration on weight. In most cases this is the manufacturers number is usually off by a 1000 lbs or more by the time you add gear and accessories. I would assume that a leasing company wants to know the tare weight of your truck so they can size loads appropriately. This means fill it up with fuel and head to the nearest scale to get a print out.
    Length they are looking for is wheel base most likely. Measure from the center of the front hub to the middle between the drivers. That is your length.
    Value is whatever you want it to be within reason. Unless it's an exceptional Columbia of that age, you are probably looking at $20K.
  8. Mdsd82
    Dec 15, 2020
    Just want say thank you all so much. I had thought yeah just take to a scale and measure from front to back but I wouldn't have known to go axle to axle or to fuel it up first. Also I know the truck is worth more than the 3k we paid just no real clue how much more. tyvm I'm still trying to learn all the little things that I didn't need in the company truck. You all are life savers
  9. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
  10. bad-luck
    bad-luck Road Train Member
    3,319
    6,102
    Nov 16, 2013
    Baltimore, Maryland
    Used to be a cushioned pad mounted on the dash above the glove box. Pop it off and there should be a large sticker there with all the info. As for the value go on to truck paper and search for the same truck and mileage as your truck, and you will have an idea
    Mdsd82 Thanks this.
