Please somebody can help me ?? -->> J1587 Communication Error With Vehicle ECU
Discussion in 'Volvo Forum' started by 666999, Mar 17, 2013.
  1. 666999
    666999 Bobtail Member
    9
    Mar 17, 2013
    Anyone can help me ?! plz !
    Vehicle : 2007 Volvo 630, Cummin's engine, Trans: Auto "[]" Eaton 10 speed.
    I stopped on middle of the road.
    My truck is shut off, after couple miles when I saw on display message " J1587 Communication Error With Vehicle ECU ".
    I Try it to disconnect batteries for 15-30 minuts.Problems not resolved.
    Problems:
    1) truck starts oK, but PTO doesn't work , display shows sign CHECK then after couple seconds coming message -->> " J1587 Communication Error With Vehicle ECU "
    2) transmission all time -->> "N" and doesn't wanna shift at all, when I try to shift put on "D" or "manual" blinking green light and noising, not moving at all.
    3) Engine break switch not working, lights not coming on.
    4) Red Parking sign on display "P" not coming on, but both breaks working oK.
    On View Active Faults shows:
    Engine ECU
    -> MID 128 SID 231 FMI 9
    Brake ECU
    -> MID 136 SID 1 FMI 2
    Instrument Cluster
    -> MID 140 PSID 201 FMI 12
    Light Control Module
    -> MID 216 PSID 201 FMI 9
    here is on => Vehicle ECU every time after I try to reset shows Operation Failed or Reset Failed.
    Please If anyone has idea or if it was on the same situation help me !!! Thank you !!!
  3. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    Are you still stuck in the middle of the road? Two things I can suggest, if you can check your battery connections that they are good and clean, no green stuff. Also, I had a Volvo which had a fuse in the battery box which supplied power for the ecu. If you have this, take it out and clean it up. Emory paper is the best, but file, nail file, or pocket knife, just to get the corrosion and oxidization off the end. Good luck!
    ChromeNut and 666999 Thank this.
  4. 666999
    9
    Mar 17, 2013
    Yes Sir, I checked all the connections and cleaned with sand papers well. still the same problem.
  5. 666999
    9
    Mar 17, 2013
    plz, waiting for help.
  6. bravoo67
    bravoo67 Light Load Member
    252
    35
    Mar 15, 2012
    Brooklyn NY
    I would check all the connection on LCM and VCU
    have you been doing anything under console where the fuses are ?
    If yes check if all the cables are plugged in in to LCM and VCU... they should be under the fuses.. just unscrew fuses board and everything should be under
  7. bravoo67
    252
    35
    Mar 15, 2012
    Brooklyn NY
    also you could check the plug with a looooot of cables in it on the wall in engine compartmen right by the foot breake valve with green and red air hoses..drivers side ofcourse there is a screw holding it in place but you never know :)
    or it coudl simply be your ignition switch.. one you turn the key in
  8. 666999
    9
    Mar 17, 2013
    yeap ,I already checked all fuses, they are good.. still have the same problem
  9. Driver of the year
    Driver of the year Medium Load Member
    442
    249
    Sep 28, 2012
    Tampa FL
    Call a police and wrecker if you are still on the middle of the road. Then check it out.
    666999 Thanks this.
  10. bravoo67
    252
    35
    Mar 15, 2012
    Brooklyn NY
    666999 Thanks this.
  11. 666999
    9
    Mar 17, 2013
    I checked all that too, No changes., and what is wondering me, Air Gauges on truck (Front "F") all the time showing same 110-120 psi..,but Rear ("R") going down like usually.
