PM A and B service how to?
Discussion in 'Ask An Owner Operator' started by DDlighttruck, Apr 25, 2017.
  1. DDlighttruck
    DDlighttruck Road Train Member
    1,386
    19,919
    Dec 12, 2015
    What do you look for? You have forms filled out to check off? Just looking for basic advice on how others handle their PMs. Thanks
  3. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    There is no difference to me. Oil and filters, fuel filters as needed, lube everything. I change oil every 12k though.
  4. cnsper
    5,869
    27,421
    Feb 28, 2014
    As for what to look for? Anything broken, loose, leaking and especially check ujoints
  5. passingthru69
    Cnsper, you and I think alike on oil change mileage. I still change mone at 10k milrs, due to the type of work I do
    Chrap insurance
    cnsper and DDlighttruck Thank this.
  6. DDlighttruck
    1,386
    19,919
    Dec 12, 2015
    Do you have a checklist that you check off and file? Do you pull dust shields to check brake linings? Or do you just do your PM checks at regular service intervals and fix what needs fixing then? I'm assuming like little trucks once you get them tight it's easy to keep them tight. It's a little more daunting on a big truck because there is so much more to look at. I think that the grease gun is your friend and just crawling around and being familiar with it is a good start.
    cnsper Thanks this.
  7. DDlighttruck
    1,386
    19,919
    Dec 12, 2015
    In other words grease it front to back every other weekend. Oil change every 10-12k. And do a thorough pre-trip.
  8. cnsper
    5,869
    27,421
    Feb 28, 2014
    I don't worry about oil breakdown, the issue is that it gets dirty. I don't use synthetic oil but after hearing about a 12.7 with 4.3 million and one set of injectors, overhead once a year I have just started to add Lucas to the oil. Synthetic oil gets just as dirty as regular oil so my change intervals would still be the same. I know some of you have seen these new trucks with bad cams and rollers with 500k on the clock. I attribute that to the longer oil change intervals.
    passingthru69 Thanks this.
  9. cnsper
    5,869
    27,421
    Feb 28, 2014
    No I don't have a list. Don't have dust cover either. To me it is a simple thing of repetition.
    passingthru69 and DDlighttruck Thank this.
