Pneumatic Bulk Training.
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Cyclesdalecummins07, Apr 4, 2012.
  1. Cyclesdalecummins07
    Cyclesdalecummins07 Light Load Member
    133
    23
    Sep 6, 2011
    slidell, la
    I have seeing that there is alot of waork around the country that are using Bulk trailers and I was wondering where would you go to get trained to properly operate a bulk trailer. Are most of you trained by your company or did you just go out and learn it for yourselves? I have seen that AR transport will train you but I do not have the miles to be considered for employment with AR. Also are most loads offloaded the same way for example would you unload sand the same way that you would unload plastic?
  3. andre
    andre Medium Load Member
    341
    172
    Feb 10, 2008
    Jacksonville, FL
    You'll get trained at the company. It doesn't take too long to get the basics. Then you'll learn the nuances as you go along.
    Different substances will respond to different valve settings, but they are all similar in that they all get blown out the back of the trailer through pressure. The differences are in how fast you end up offloading.
    If they don't show you how to reverse pump a tank, they haven't trained you properly. Ask them how to do it, or go on the internet and download some instructions and train yourself to do it. It's invaluable, especially for sticky stuff.
    RockinChair Thanks this.
  4. wis bang
    wis bang Road Train Member
    3,410
    4,027
    Jan 12, 2011
    Levittown, PA
    Sure beats cleaning up the mess and the customer is much happier!
    Raiderfanatic Thanks this.
  5. pathfinder1361
    pathfinder1361 Light Load Member
    256
    40
    Aug 19, 2011
    miami, fl
    i was "trained" by my company. it consisted of going out with a qualified driver 2-3 days. after that i was considered "qualified" but
    after reading all the knowledge the poster's here possess, i realize that i really only knew the basics. i was never shown anything about how to unplug anything, or reverse pump etc. with that said i didn't have any problems that i am aware of, successfully offloaded plastic pellets about 6 times at different customers. i do recall starting with the #1 hopper and working back due to the heat/melting reason.
  6. RockinChair
    RockinChair Road Train Member
    5,140
    13,017
    Feb 19, 2012
    CC, TX
    NO!!
    The physical characteristics of the product and the unloading site will determine how you unload it.
    Cement into a pig will be different than pebble lime into a tall silo. Plastic is a completely different ballgame (temperature sensitive), as is food-grade product (sanitary considerations have to be taken).
    andre and chalupa Thank this.
  7. RockinChair
    5,140
    13,017
    Feb 19, 2012
    CC, TX
    Amen to that!
    You really need to learn this - it will save you lots of time and frustration. If the company won't train you for it, ask one of the experienced hands.
    Hint: If you're doing it right, the trailer will hop up and down when you open and close the hopper valves.
  8. The Bulkmatic Grasshopper
    The Bulkmatic Grasshopper Bobtail Member
    40
    17
    Apr 4, 2012
    Kentucky
    I was company trained. With a trainer for two weeks, one w/at the main terminal, then on my own from there.
  9. Johnny99
    Johnny99 Johnny be Good
    549
    261
    Nov 24, 2007
    Big Sandy Tenn
    All the companies I knew of did their own training. Even if you had experience you got checked out for a couple of days with a trainer. If they hired you with no tanker experience you stayed with a trainer until the trainer said you were good to go solo.
  10. Raiderfanatic
    Raiderfanatic Heavy Load Member
    814
    561
    Jul 18, 2010
    Hutchinson, KS
    It's really not that difficult. You can get trained on the proper valve usage, how to unplug a line etc.. but nothing beats actually being on the site doing it yourself.
    We haul everything from food grade to sand, limestone, lime pebbles etc... Never hauled any concrete though.
    I've found with light product, like flour or limestone, you can open your product valves all the way and keep your bottom line air less than half way open. But with heavier product, like salt or sand, I never open the product valves more than half way. My bottom air I'll run 3/4 or more open. And I always use my vibrators. Never use top air except with sugar. Then just long enough to get my tank pressure up then shut the air off. Otherwise it can melt. Corn is similar. Too much pressure and it will break up as it's blowing off.
    Each trailer is different, too. But it's not hard to get the hang of. Some products just out right suck to unload. And some customers just are a pain in the rear to deliver too. You might blow off in 45 minutes at one place and take 4 hours at the next.
    Hauling dry bulk is a good gig, though. At least in my opinion. You can make darn good money pulling a pneumatic.
  11. Green Machine
    Green Machine Medium Load Member
    623
    175
    Jul 23, 2009
    I've never hauled concrete either... But I haul cement all the time :biggrin_25525:
