How you doing, just have a question. We just bought a 2005 Polar Pneumatic, air ride and our discharge hose is 5 inches from the ground. Does anybody have any advice or guidance on how to fix this issue to at least maybe a foot to foot and half? We are new to this industry and thought we had a solid trailer till we saw the ground clearance. We are hauling fly ash. Any help or leads would be great. Thanks!
Pneumatic ride height problem
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by mesas`, Feb 3, 2018.
Does your trailer have the U shaped axle for the line to go under the axle and give you more room ?
Any competent mechanic or trailer shop should be able to replumb that for you.
Yeah if you want it higher just run a rubber product hose from rear tee over the axles and secure it so it doesn't rub anything. I have the same trailer mine is this way.
If you mean your product pipe between the tees is that low that is strange. I made spacers to lower the king pin plate which raised the front of the trailer 3 inches to help with load distribution. But didn't have ground clearance issues.
