pneumatic tanker experience?
Discussion in 'Oilfield Trucking Forum' started by postmandav, Oct 1, 2014.
  1. postmandav
    postmandav Medium Load Member
    313
    90
    May 18, 2008
    south portland, maine
    I worked for a food grade water hauling company for about 1 month a few years ago. All pumps that were used were not actually on the truck. How different is this from a vacuum tanker in the oilfield? I am wondering if I would be considered a complete newbie or experienced? 5.5 years of cdl a driving but only that short time hauling tanker.
  3. HeWhoMustNotBeNamed
    HeWhoMustNotBeNamed Crusty Pogosticker!!
    3,454
    19,721
    Jan 25, 2012
    Cartoon Network
    5 years experience is plenty to get a job. But a Vacuum tank is not a pneumatic, research it so you know what job you want. Both types carry onboard pumps on the Truck or Trailer.
    postmandav Thanks this.
  4. row684
    row684 Bobtail Member
    42
    24
    Oct 1, 2014
    I was wondering about the different kinds of pumps as well, I drove a tanker hauling whey and it just had a pump on the back fender, and oilfield friend said they referred to that type as a "junk pump" I think he said?? He drives a water tanker that sucks the air out of the tank drawing the water in, I believe he called it a "kinetic pump?" He also said that their is a third kind on another truck that he sometimes drives but didn't get into how that one worked, maybe this one was the "kinetic."
  5. postmandav
    313
    90
    May 18, 2008
    According to the quick research I did, *20 minutes^, pneaumatic trailers are used for dry bulk work. Would t be safe to say that the trailer I was pulling was just a foodgrade smoothbore trailer since it relied on pumps that were not hooked to the trailer itself?
    HeWhoMustNotBeNamed Thanks this.
  6. HeWhoMustNotBeNamed
    3,454
    19,721
    Jan 25, 2012
    Cartoon Network
    as far as I know. I haven't operated any tank except pneumatic.
  7. Powder Joints
    7,514
    7,423
    Sep 25, 2007
    Rosamond, SoCal
    This is not necessariy true, Some of the Dry Bulk Semi trailers are rated for pressure and vacuum, I pulled one for APEX back in the 90's that was both Dry Bulk Vacuum/Pnuematic used a PTO drive garner denver type blower.
    Liquid Vacuum is a different story, the compressor for this set up can be mounted on the front of the trailer or on the frame of the tractor, the garner denver can be used for either application but it is not a liquid pump.
    Food grade / Petroluem / Smooth Bores / normally use a liquid pump.
    At APEX my tractor had 2 pumps left was a dry garner denver, and the right was a liquid pump both were PTO drive. I also hauled liquid in the Dry Bulk pnuematic Semi ( also pulled doubles used the same ).
    Liquids were gravity unload mostly, except for long pushes.
  8. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    i think he is talking about a vac trailer. liquid tanker pulls a air vacuum on the tank to suck liquid in pressurizes air in the trailer to push liquid out, very common in the oil fields. pumps can be mounted on the trailer or the truck and are powered off a pto.
    a pneumatic trailer is a dry bulk trailer, and are also used in the oil feilds to haul sand.
  9. JPenn
    JPenn Road Train Member
    1,829
    1,873
    Mar 5, 2008
    Northern Tier PA
    EZ clarified the equipment part, so I'll be the jerk and pick on this :)
    Unless you have oilfield experience, you're a newbie. If you're only working with 1 month tanker experience, you're a newbie. Don't sweat that, everyone was once. Just don't carry on like you've got experience if you don't, because everyone else can spot it from a mile away, and it brings nothing but trouble.
  10. postmandav
    313
    90
    May 18, 2008
    That was the exact answer I was looking for.
  11. postmandav
    313
    90
    May 18, 2008
    Yes, I was talking about a vacuum trailer.
