Popping and rubbing sound at low speeds and when turning
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Heavy_T, Jun 28, 2021.
  1. Heavy_T
    Heavy_T Bobtail Member
    This just started as I was pulling in a rest area tonight so I kept driving around and noticed it sounded pretty loud. Sounds like it's coming from the front end. Hubs look good and brakes don't look too bad so not sure what it is. It makes a rubbing sound at really low speeds and pops when turning. Almost sounds like a dry 5th wheel but I just greased the 5th wheel yesterday. Obviously taking it to a shop is best bet but just looking to see if any of you guys have any ideas what it could be. I'm not the most experienced driver. Been out here for about 2 years so still a lot to learn. It's a 2012 volvo 670
  3. okiedokie
    okiedokie Road Train Member
    12,348
    92,382
    Jun 13, 2011
    PNWET
    Check your steering linkage, Lug nuts, tie rods,ect for loosening.
  4. Goodysnap
    Goodysnap Road Train Member
    3,718
    9,032
    Jul 12, 2017
    Most likely dry or worn spring pins/bushings. Thorough front end inspection by a qualified individual should find the problem in short order.
    clausland and rollin coal Thank this.
  5. Big Road Skateboard
    6,190
    34,007
    May 2, 2021
    Yeah. Spring shackles have some slack in them. They can be shimmed up. Spring is on one side of the pin, and without the correct shims, there is room between the Spring eye and shackle.
    Make a turn, especially when loaded, and it slides over, popping pretty loud.
    DUNE-T Thanks this.
  6. boneebone
    boneebone Road Train Member
    2,296
    2,367
    Mar 13, 2009
    Worn or dry spring bushings or dry kingpins.
    Grease is cheaper than parts
    Regen Again? Thanks this.
  7. Regen Again?
    Regen Again? Bobtail Member
    17
    5
    Oct 1, 2011
    Brooklyn, NY
    This.
