Popping loosing power n14 Cummins
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Junior512, Aug 3, 2020.
  1. Junior512
    Junior512 Bobtail Member
    I have a Pete 379 with an n14 Cummins and I’ve been having a problem for the past weeks I get a popping sound and loose power some white with black smoke starts happening I have to get off gear then back to help it start working again And it also a only happens when I’m in high gears and I have taken it to some mechanics but they can’t find the problem what I have done lately I have changed the turbo I also changed the air cooler because it was damaged but it keeps on doing the same thing...... can anyone point me to a right direction
  3. singlescrewshaker
    4,852
    42,408
    Dec 31, 2017
    Little Havana, FL
    I had a similar problem with my ddec ii series 60. The injector heights were way out of spec after a terrible overhead job. Same symptoms you describe.
    Kind of a popping sound out the stacks
    No power in top gear
    White gray smoke in top gear
    Couldn't barely pull an overpass with an empty wagon..
    Brettj3876 and AModelCat Thank this.
  4. AModelCat
    161,682
    Sounds like it might be an injector dumping fuel.
    Brettj3876 and singlescrewshaker Thank this.
  5. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Do a cyl cutout test?
  6. Junior512
    The thing is that popping sound kind of comes on the passenger side like it’s hitting my cab
