Popping sound on rear while trailer is getting loaded
Discussion in 'Ask An Owner Operator' started by JD Transport, Aug 8, 2015.
  1. JD Transport
    JD Transport Light Load Member
    53
    17
    Sep 24, 2014
    Just curious, bought an Intl 9400 (2001). once I'm backed into the dock, with the truck off (This is my first stop of the day so the trailer is almost empty), the forklift driver must come to the front of the trailer and I noticed it presses down on the rear of my truck, causing a popping sound to come from somewhere. My thought was that its a u bolt that needs replacing or the shocks maybe, air bags will hold air for almost 2 days when the trucks just sitting at the yard, so I'm pretty sure those are not the problem. Leaf springs look good, none missing. Just wondering if I should be concerned a about this popping sound. Driven many other company trucks with various sounds but this one is my own so I'm trying to stay on top of things.
  3. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Brakes slipping. When the brakes are set and the suspension compresses it binds the brakes. There has to be give somewhere. The trucks ive driven with maxi chambers on only one axle were worse about it. I dump my tractor suspension and trailer too if it has a dump valve before setting my tractor brakes.
  4. JD Transport
    53
    17
    Sep 24, 2014
    That makes sense, brakes are new. I know the truck needs some shocks cause it's like riding a #### horse at times goin down the road. Thanks for your input Keith, I'm kinda hypochondriac as a new owner op lol
  5. KeithT1967
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    With the ih suspension there are a few other possibilities for popping. Ive put over a million miles on a pair of 9400's. I think ive heard every noise they can make. Another source of strange noises in the rear are missing slip blocks. Where spring sits in the rear suspension mounts should be a white plastic looking pad with two bolts holding it in. If you have any missing it will pop and squeak.
  6. JD Transport
    53
    17
    Sep 24, 2014
    The trucks currently at the company yard but I am going to go look at it n see if they are missing. The steering shaft is getting looked at next week, not pleased with the play & movement. Besides the complaints I mentioned I'm pretty happy with it, it's a local 300 mi a day hauler
