Portable battery jump starting. Hook ups and 12 or 24 volt
Discussion in 'Experienced Truckers' Advice' started by Freightshakersfolife, Nov 16, 2022.
  1. armo
    armo Light Load Member
    274
    290
    Jun 16, 2022
    use it on cascadia and your truck will be junkyard's candidate.... it will burn all modules ))))
  3. AModelCat
    161,299
    Cat skid steers have been 12 volt for the last 15 years for sure. Most larger construction machines run 24 volt systems. I'm guessing since most of it is built overseas now.
    tscottme, snowwy and D.Tibbitt Thank this.
  4. Allow Me.
    10,720
    12,410
    May 28, 2009
    Rancho Mirage, Ca.
    When I drove a tow truck (6 wheeler) years ago, we use to jump start VW bugs (6 volt battery) with our 12 volt jumper battery. But, it was a very quick connection, not a minute grinding on the starter.
    tscottme Thanks this.
  5. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,263
    Nov 16, 2012
    SW FLA
    I have one of these
    Had dead batteries once and the TS wanted $150 to hook up
    Car hauler pulled in next to me and let me use his. It was a little smaller but jumped my truck no problem
    Last week another driver asked if I’d jump his truck and I hooked this up and 69 seconds started his completely dead truck
    NOCO Boost Pro GB150 3000 Amp 12-Volt UltraSafe Lithium Jump Starter Box, Car Battery Booster Pack, Portable Power Bank Charger, and Jumper Cables for up to 9-Liter Gasoline and 7-Liter Diesel Engines https://a.co/d/0wIrGut
  6. Moosetek13
    Moosetek13 Road Train Member
    14,812
    18,698
    Nov 1, 2010
    Burnsville, MN
    The only computer controlled thing in those bugs was the little lever to open the heat vent by the drivers foot.
    A human computer that isn't subject to higher voltage.
    I wonder if the NOCO would sense the 6V system in those bugs?
  7. GYPSY65
    1,957
    5,263
    Nov 16, 2012
    SW FLA
    Didn’t read it all but looks like this one does
    NOCO - Genius Multi-Purpose Battery Chargers
    Moosetek13 Thanks this.
  8. skallagrime
    skallagrime Road Train Member
    3,850
    9,923
    Apr 10, 2012
    Indiana
    GYPSY65 Thanks this.
  9. Lazer
    Lazer Road Train Member
    1,826
    2,919
    Jan 22, 2017
    Previous employer had a ‘jump box’ that was supposedly 18 volts. Used it many times over the years I was there, Pete’s, KW’s, FL’s all were introduced to it, never fried anything.
  10. tscottme
    tscottme Road Train Member
    My 2018 Cascadia had jump start posts on the tractor frame under the hood between the right steer tire and the firewall. I would think the best way to use one of those jumper start carts is to turn EVERYTHING off inside the truck, or use the battery disconnect switch, connect the jumper device and just let it charge the truck battery for a few minutes and then when you can't wait any longer try cranking over the truck engine. The truck batteries won't mind having 24 volts applied to them, I don't know if the 809 computers in the truck will like it or not. To me a truck is just a tool, not a work of art, or delicate instrument, or a statement about me to the world. I've only been a company driver. If my truck was stolen or burned to the ground I would just ask for another truck.
  11. GYPSY65
    1,957
    5,263
    Nov 16, 2012
    SW FLA
    Good eye
    Better than mine but I’m fixing that next month
    Getting new lenses put in
