Portable battery jump starting. Hook ups and 12 or 24 volt
Discussion in 'Experienced Truckers' Advice' started by Freightshakersfolife, Nov 16, 2022.
  1. beastr123
    beastr123 Road Train Member
    2,916
    23,892
    Jan 2, 2014
    Moose Jaw SK CAN
    With the coolant heater get the timer and set it to start 2 hours before you want to start the engine. You can start after 90 min heater time down to -30F.
    The air-heater uses much less power per hour but you will need to charge your batteries after 10 hours run time at -5F or you will need a boost.
    This goes for modern Webasto and Espar heaters with the exception if the Webasto 2010which is a coolant based heater that has 2 to 3 times more btu than modern systems.
    skallagrime Thanks this.
  3. skallagrime
    skallagrime Road Train Member
    3,853
    9,925
    Apr 10, 2012
    Indiana
    It is a coolant heating chinesium grade "hcalory"
    We shall see what happens, in the meantime, ill have the booster with me
    beastr123 Thanks this.
