Portable CB Radios
Discussion in 'Questions To Truckers From The General Public' started by MEA, Jan 12, 2007.
  1. MEA
    MEA Bobtail Member
    First-off thanks in advance for the tips,
    I work for a locall run company and I'm at the bottom of the tottem pole, so I have to jump truck tah truck day tah day, none of the trucks they shuffle me in have CB's... Which is very frustrating when you pull up to a security desk and a sign says tune into channell 2 and you have to ask a disgruntle guard personally were to put your rig, and he sarcasticly lets you know....
    Anyways I was wondering if anyone could recommend not top off the line, but good portable CB...Under $150.00 dollars if possible...Thanks
  3. jamwadmag
    jamwadmag Road Train Member
    1,119
    107
    Feb 28, 2006
    Desert Southwest
    I slip trucks weekly, and many of the older ones have bad CB antennas. So I started using a handheld. I bought the cheap & dirty $45 Wal-mart couple of years back. It has the regular max legal specified 4 watt output, 40-Ch, etc.
    It definitely has it's limitations: can usually hear everbody out there (esp. those w/linears), but braodcast range is limited inside the cab. I mainly use for dealing with custs & listening to weather/bear (CA!) reports. Nice to carry on person if waiting for cust notification and still want to 'move around.' The 12-volt input jack is worn out, and takes 9 of 1.5v AA batteris. If really important & want to use daily on the road, I'd say get an 'up-scale' handheld---stay with brand names that have good track records.
  4. pro1driver
    pro1driver Heavy Load Member
    939
    47
    Mar 30, 2006
    North East, USA
    i wouldn't get a "hand-held" cb radio.
    i would say to get a cheap radio shack cb, or maybe get a midland/uniden/cobra "mini" cb, usually under $60.00 and less on sale, or the internet. then, i would get the "vise-grip" antenna mount, a 2-or 3 foot Francis fiberglass antenna, and about 9 feet of coax.
    now, you would have a "spare" set-up, and can attach the vise-grip mount to the mirror bracket, maybe use a bungie cord to hold down the cb to the dash, plug into the cigarette lighter, or use the dash mounted power studs....................
    all can be had for under $100......................
    then, when you get into your own rig, or move onto another company, you store this "Spare set-up" into a storage compartment in your rig, and buy a bigger cb radio. this way, you'll always have a "real" cb radio instead of a really useless hand-held unit...........
