2015 cummins isx while doing an oil change. I was installing the new oil filter and as I'm getting it into position it touched a hose and some specs of dirt might have fallen into the filter. Can't confirm as I didn't check it but there's a chance. Question is. Would that be able to do damage? Or would the oil filter catch that before it would do any damage?
Possible dirt in oil
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Petegraintrain, Nov 14, 2021.
If some fell in to the center hole of the filter, they are going to end up in the engine. The filter will catch them the second time around. I wouldn't worry too much though. The oil goes to the crank bearings and piston cooler nozzles first. The bearings are designed to allow particles to imbed so they don't cause further damage, and the oil from the nozzles ends up in the pan to be filtered again. You might end up with some scoring on some surfaces inside the engine, but as long as it doesn't happen regularly, and the specs aren't big, you wont have any significant damage that would noticeably shorten the life of the engine.
biopure22 and blairandgretchen Thank this. -
Either way, it’s not good. But as stated the filter will catch it, but will any damage be done before it does?
You notice how we don’t change rods and mains anymore?Pamela1990 and Oxbow Thank this. -
If you knew right away, why not take the filter back off, shake it out, or better yet just toss it in the garbage, and use another new one.
Don379 Thanks this. -
Uh oh, if i was you, i would pull engine and completely disassemble for a full and thorough forensic investigation. Thats the only way to be sure. OR you can take option number 2. Option number 2 is to not worry so much and just drive the truck and change the oil next interval
Goodysnap Thanks this.
