Possible to register truck at lower weight?
Discussion in 'Trucking Industry Regulations' started by Thetrashnoob, Jul 5, 2020.
  1. Thetrashnoob
    Thetrashnoob Light Load Member
    299
    57
    May 30, 2019
    So I found a decent deal on a dump truck for a side hustle I wanna do, issue is it’s 33k pound truck, is it possible to register it at 26k so no need for a cdl? The dmv is the one saying I can do this but doesn’t make sense to me
  3. buzzarddriver
    3,643
    10,662
    Feb 1, 2011
    Dallas, TX
    The DOT guy is going to look at the door sticker to see the mfg rating when you get stopped and don't have a CDL. Then you might have the argument over fake registration if the registered weight is way below the mfg weight rating.
    And what would be the purpose of registering below the mfg weight rating?
  4. Powder Joints
    7,809
    8,010
    Sep 25, 2007
    Rosamond, SoCal
    Yes, companies like Pepsi and Coke do it all the time, 3 axle tractors registered @ 24 to 54 instead of 80. But his also opens you up to overweight tickets at a lower rate. So make sure you never gross more than the road taxes you chose.
    bzinger Thanks this.
  5. Accidental Trucker
    Accidental Trucker Road Train Member
    3,369
    7,397
    Jun 4, 2015
    Yes, you can register up OR down from the CGVW -- but DOT goes by CGVW. I've done both, usually because it's cheaper to register down, or to avoid over weight tickets (think pickups with trailers.) Scale house inspectors tend to think in terms of pounds per axle and as long as all that is good, they don't generally look at the actual GVW. But on a full level I, I'd not want to be in a 33K truck without a CDL.
  6. D.Tibbitt
    152,267
    it aint that hard to get a cdl .
    clausland Thanks this.
  7. Thetrashnoob
    299
    57
    May 30, 2019
    Never said it was hard, just don’t have them time to get it, that’s the issue
  8. D.Tibbitt
    152,267
    It takes maybe all of 2 hours.
  9. D.Tibbitt
    152,267
    In the amount of time u spend figuring out how to register ur rig , u could have a cdl with all ur endorsements
    WildTiger1990 and skellr Thank this.
  10. Thetrashnoob
    299
    57
    May 30, 2019
    I’m not so sure about that one. I wanted to do the class to get my class a but I don’t have 4 weeks I can take off from work right now to do the class
  11. D.Tibbitt
    152,267
    U dont have to go to school to get a cdl.
