Post Amerage Maximum?
Discussion in 'CB Radio Forum' started by Airbus, Apr 14, 2015.
  1. Airbus
    Airbus Light Load Member
    74
    12
    Sep 15, 2009
    Rochester, NY
    Does anyone know what the maximum amperage is that can be run through the power posts on top of the dash on a Cascadia?....:"
  3. Ridgeline
    22,664
    121,315
    Wow we were just talking about this very thing this morning.
    I got this from the supplier for FL, the binding posts are rated at 16 amps. They can take up to 20 amps but may get warm.
    BUT that said, it depends on what the fuse is that protects the circuit.
  4. Airbus
    74
    12
    Sep 15, 2009
    Rochester, NY
    Ok.....I'm planning on getting my Ham ticket and most of the dual band radios draw around 15 amps on transmit at full power (75watts)....Thanks..
  5. Ridgeline
    22,664
    121,315
    You should be safe with that, it is those cb things with a swing that seem to take the toll on them posts.
    Good luck with your ticket.
  6. Airbus
    74
    12
    Sep 15, 2009
    Rochester, NY
    Thanks....I should be taking the test on June 6th.....:)
  7. mntrucker
    mntrucker Bobtail Member
    15
    Apr 7, 2015
    20 amps is usually about the limit, though my memory isn't as good as it once was ;)
