Poured a gallon of of antifreeze aluminum seal went in tank??
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Big Lou, Sep 13, 2013.
  1. Big Lou
    Big Lou Light Load Member
    155
    25
    Aug 15, 2013
    Tampa, Florida
    Can this little aluminum seal on the top of the gallon of antifreeze went in my fill up tank will it hurt anything. Thanks
  3. Flatbedn
    Flatbedn Road Train Member
    1,307
    784
    Nov 12, 2012
    If it blocks a coolant line or ends up in the water pump yes it can cause overheating.
  4. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    Well you better run it for a good long time before you shut it off, It will find a leaking hole or whatever you wanted it to but it may seal up a small passage way in the block or anywhere else and cause like stated before a over heating situation, What is the reason you put this in there for? Good Luck.
  5. Flatbedn
    1,307
    784
    Nov 12, 2012
    He is talking about the foil that is under the cap on the jug of antifreeze.
    truckon and Big Lou Thank this.
  6. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    its likely still in the expansion tank where you poured the coolant in, id try to see if i could fish it out.
    btw i read it wrong at first too as there is a radiator stop leak called alumi seal or something very close to that.
  7. D.Tibbitt
    143,916
    fish it out before it block a line
