Power divider input shaft broke? Driveshaft turns, truck does NOT move
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ichudov, Jul 2, 2019.
  1. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    In layman's terms, power is going to take the path of least resistance. Hence spinning wheel or broken spider gears in your power divider. . I would replace the whole power divider with a reman.
    Goodysnap and Diesel Dave Thank this.
  3. ichudov
    ichudov Heavy Load Member
    742
    642
    Mar 14, 2012
    Berkeley, IL
    Thanks. Some mechanic that I know suggested also to replace the middle axle differential at the same time. Would you agree?
  4. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    All depends on how many miles are on it and how it's been used. If ring pinion look good and carrier bearings are tight you probably be fine just replacing power divider assembly. How's the oil look? Full of metal ?. If all else looks good run it.
    Bean Jr. Thanks this.
  5. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    470k miles. Quite a bit of metal on the bottom magnet. We are taking off the diff assembly right now to look at it.
  6. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    That metal is prob all from the pooched powerdivider. With those miles I wouldn't be afraid to throw a reman power divider in and run it.
    It likely let go from extream shock load . Only way you explode the spiders gears like that.
    Goodysnap Thanks this.
  7. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    We took out the differential. It is in HORRIBLE shape. Piles of metal stuck to magnets on the bottom. Also broken differential teeth.
  8. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    We have a mechanical gooseneck trailer. I am thinking that "shock loads" may have something to do with it?
  9. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Well that settles that then LOL. I think I'd be looking more of the driver than what trailer you're pulling
  10. ichudov
    742
    642
    Mar 14, 2012
    Berkeley, IL
    OK, we found a replacement at a local drive train company and it carries a 2 year warranty.
    Bean Jr. and swaan Thank this.
  11. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Good that was quick.
    Bean Jr. and ichudov Thank this.
