Power inverter(400w) wont power my desktop pc
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by cturn44, May 20, 2020.
  1. Mid-May Trucker
    Mid-May Trucker Road Train Member
    1,118
    2,079
    Oct 23, 2018
    1. How much power desktop use.
    2. Going dc to ac to dc waste a lot of power.
    86scotty Thanks this.
  3. MidWest_MacDaddy
    11,199
    18,906
    Feb 21, 2015
    South Carolina
    The laptop solution might avoid the issue all together as it can, if needed, boot up using its own battery for that initial power spike and then plug it in and use the inverter to simply top off the battery either after boot up or between uses.
  4. WIlee81
    WIlee81 Light Load Member
    176
    248
    Aug 19, 2019
    SE Louisiana
    The best way to go about it is to find out how big the power supply in your PC is. Either search the model number online and try to find the specs or just open it up and look for yourself. There's a label on the power supply that has the wattage rating. Once you have that, find a pure sine wave inverter that is rated for at least 35% more wattage than your desktop and have it installed.
  5. jbgrim72
    jbgrim72 Bobtail Member
    28
    8
    Apr 18, 2017
    i have a cobra 2500 inverter and it powers my laptop and brother printer in my truck and charges my 2 phones at the samre time no problems at all
  6. 86scotty
    86scotty Road Train Member
    4,503
    12,198
    Aug 27, 2017
    Appalachia
    I run a 2500 as well. I found it pretty much covers whatever I can stuff into a truck.
  7. Wasted Thyme
    7,729
    38,304
    Jan 27, 2020
    GOAT watching
    Laptop won't use the inverter to "run" but to charge the battery. I've a 400watt cheap one. Running through the 150watt outlet. I have no issues running it. Usually run the engine 10-15min every 60-90min to recharfe the 12volt car battery. But it keeps the laptop battery topped up no issues.
  8. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    You will need to run some wire to the battery for the invertor to run at full capcity and even than you may lose some power through inefficiency . 450 watts can power most mid range pcs but 400 is pushing it and even if it does at start up it may neew a extra 100 watts to boot .
