Power inverter question.
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Kfd314, Dec 7, 2016.
  1. Kfd314
    Kfd314 Bobtail Member
    6
    If I wanted to power a single electric burner (1100 watts) could I use a 12v power inverter?
  3. Gunner75
    Gunner75 Road Train Member
    5,701
    9,074
    Mar 17, 2014
    Jackson Center Ohio
    No, you won't get much more than 300 watts from a 12v connection, all you'll end up doing is blowing the fuse, and if you put in a higher rated fuse, you'll just cause something to melt and then possibly a short or even a fire
  4. Kfd314
    6
    What would you recommend doing to power a burner like that?
  5. TheDudeAbides
    TheDudeAbides Medium Load Member
    374
    455
    Dec 5, 2014
    San Antonio, TX
    I have a 2000 watt invertor hard wired to the batteries and use use a little single burner hot plate but I have to run my APU or idle the truck or else it drains the batteries very quickly
  6. Gunner75
    5,701
    9,074
    Mar 17, 2014
    Jackson Center Ohio
    Well it says it's an 1100watt burner, so you'll need an inverter that can sustain at least 1100 watts, so I suggest at a minimum 1500watt sustainable inverter, and the only way to install one of those is to hard wire it straight to the batteries.
  7. Gunner75
    5,701
    9,074
    Mar 17, 2014
    Jackson Center Ohio
    No offense here but don't be stupid and try to play around with this stuff, drivers have died because they tried to circumvent wiring an inverter in incorrectly.
  8. Kfd314
    6
    Thank you, that's why I asked first. I don't know much about that stuff.
  9. NorCenArk
    NorCenArk Light Load Member
    76
    35
    Mar 31, 2011
    Russellville, AR
    Recommend a pure sine wave inverter over a modified sine wave the truck spots sell. Everything works much better. Will cost a bit more but we'll worth it. I had a 2000 watt Xantrex pure sine that worked great. They are about 350+.
  10. Ridgeline
    22,385
    116,220
    NOT all inverters, even the good expensive ones are designed to handle inductive loads so be careful to ask or check before plugging it in.
