Hello,
I am a new driver and my friend is a trucking broker. He has power only loads from CA to Co. and wants me to do 5 loads per month. My question is, how hard is it to get a power only load from Co to CA.? Since I have power only loads from Ca to Co. If I can't find loads from co to ca. then The d/h miles are far to much. Thanks!!
power only from CA. to CO.
Discussion in 'Questions From New Drivers' started by salidaco, Jan 24, 2012.
Your probably not going to find many po loads from co. Your rate out of Cali really should be enough to cover the dh back if your working a dedicated deal like that.
Just pulled up a power only search from Colorado to California for you. NOT ONE LOAD as of right now on Getloaded.com site. Usually a pretty good site for loads. Hope that helps you out a little.
Thanks for the info guy's. And thanks for checking on the p/o load boards!! I didn't fugure on many po. loads from co to ca so i'll probably put the dh in the cost. Thanks
