power outlets not working (which fuse)
Discussion in 'Trucks [ Eighteen Wheelers ]' started by guru2323, Apr 20, 2013.
  1. guru2323
    guru2323 Bobtail Member
    17
    Jul 16, 2012
    hi i have a 2005 freightliner Columbia and the all power outlets stop working cant charge phone and other stuff , does anyone know which fuse it is, the name of it plz thank you for your help
  3. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    Get your test light out and just go through all the fuses. Much faster then trying to decipher the map on the fusebox door.
    guru2323 Thanks this.
  4. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    The sleeper power is usually behind you're seat for the front it should be in the fuse panel when you look it should have it written right next to the fuse that's how freightliner a do it for the back two behind you're seat there is a door you can open from one bolt with a flathead screw driver once you open door there is a small covered fuse box look for 15 amp fuses the should say LHRC and RHRC those are the two fuses u need
