Power Steering Fluid
Discussion in 'Trucks [ Eighteen Wheelers ]' started by American-Trucker, Jan 28, 2012.
  1. American-Trucker
    American-Trucker Road Train Member
    10,371
    5,085
    Nov 8, 2009
    Charlotte, North Carolina
    2007 379 with a C15, i'm low on Powersteering Fluid, can i just get the stuff in the auto section of the TS or do i need some special stuff for trucks? (note: i dont see power steering fluid on the big truck side of the store)
    American Trucker
  3. 98989
    98989 Road Train Member
    5,990
    6,740
    Sep 14, 2008
    i fill ATF oil (automatic transmission fluid) in both systems
    Oxbow Thanks this.
  4. 25(2)+2
    18,749
    45,388
    Sep 18, 2006
    the road less travelled
    You don't see anything on the truck side because many fluids can be used, and you should use what is already in the reservoir, be it engine oil, type F transmission fluid, or something else.
    If you have a company shop, call and ask before doing anything.
    American-Trucker Thanks this.
  5. American-Trucker
    10,371
    5,085
    Nov 8, 2009
    looks like transmission fluid its red and has a very sweet smell to it
    American Trucker
    25(2)+2 Thanks this.
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    In 90-s 15w40 oil was recomended, but I use any mineral ATF (dextron) becouse whent it is cold like now here with motor oil in PS I had to turn steering wheel gently from lock to lock twice before start!!!!
  7. king Q
    king Q Road Train Member
    2,880
    3,032
    Jul 26, 2010
    Johannesburg sa
    We used to use engine oil15W40 with no issues.
    Now I see our shop has switched to ATF.
    Same stuff you find in the car section.
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Hah, it is -22 dgr C here now!
  9. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    I recommend 15/40 it stays stable at a higher heat than ATF, and you do not need a special, additional fluid in the truck. Some drivers cause a lot of PS problems they are the ones that are always twitching the wheel.
    If the system has ATF and it is burnt, then you want to go to 15/40 if it has ATF and it is bright red leave it alone.
    When ever I had a system apart and drained I always added 15/40, especially when I was changing the PS pump.
  10. Diesel Dave
    8,535
    23,611
    Jan 20, 2010
    Hesperia, Ca.
    I use strickly Hydraulic fluid. It's non-detergent.
    Last Call and KB3MMX Thank this.
  11. rbht
    rbht Heavy Load Member
    888
    525
    Jan 23, 2010
    CT,NH
    I use hydraulic oil also. No issues.
