How important are they really? I mean back in the old days, trucks didn't have this nonsense. My 2013 Volvo has it, which is at the lower left side of the truck, where the fan doesn't hit it and the only air it gets at all to it is through the opening in the bumper and what air travels under the truck as I drive. Mine sprung a leak on me in San Simon, AZ. It's "so important" according to the Volvo dealer I spoke to, that no dealer or even any other "supplier" had it from California all the until you get to DFW in Texas. So the only option I had was to bypass the cooler by just using a brass piece of pipe that was barbed and putting the hoses to that to make a loop. The power steering actually feels 100% better than it did with the cooler before it leaked. Doesn't make any noises whatsoever and I can turn my steering wheel with my pinky. The part itself is $298.00 at Bruckners in Dallas, Texas. There is a kit that is on back order that has everything needed to replace it, that is found online for $199.00 and includes the same part that Bruckners wants $298.00 for alone. The kit however comes with the clamps, rivets and the bracket to actually install the cooler. The junk that is on there right now that leaks, even if I got the part to replace it, I couldn't put it on due to not having all the other stuff, or could I?
Question after reading that long probably irrelevant rant: is it really necessary or just a fluke to even replace the cooler?
Power steering heat exchanger (cooler)
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Stringb8n, Jul 26, 2023.
Exactly my thoughts, if it didn't need it why even have it? Car or truck. Heat kills a lot of things. Even at a high air temp and little air flow the air is much 'cooler' than the fluid and heat will radiate out of the cooler.
Power steering fluid temperatures generally range from around 180°F to 250°F12. Operating temperatures above 250°F can cause the fluid to break down, leading to reduced performance and possible power steering system damage1
We talked with Tom Lee of Lee Manufacturing who builds racing power steering boxes, and pumps and he prefers the fluid temperature at 180 degrees F, but he also says anything below 250 degrees F is acceptable. What will kill pumps is temperatures exceeding 300 degrees F.
"includes the same part that Bruckners wants" Is it the same quality?? A lot of junk out there.
"even if I got the part to replace it, I couldn't put it on due to not having all the other stuff, or could I?" Depends, would need to see pics. Curious to know if Bruckners even sells a kit to go with the cooler. -
But I do remember a brand new 2020 Volvo I drove with 650 miles on it, sounded the exact same as my truck turning the steering wheel. In my truck though, the cooler cracked or whatever and squirt all the fluid out, bypassed it, refilled the reservoir and no noises or whining or hearing pressure change when turning the wheel or any of that junk. Held up driving home to Texas from Arizona. About scared the crap out of me when the cooler did give out, cause I felt it. It gave the wheel a little jerk driving a straight line. Thought I had lug nuts on a steer come loose or something. -
Here is the part itself, it cost more from this particular supplier than the kit that includes this part and all the other stuff. Volvo Truck 21584083 Heat Exchanger, Steering Oil
And here is the kit Volvo Truck 21590718 Heat Exchanger Kit, Steering
I would prefer to do the work on it myself. I think I would have to drop the bumper maybe. But I don't see any point in paying someone whatever their labor is to loosen some bolts and put that new stuff on there. But man I am going to be so dang mad if I get all the noises and everything back all because I put a new cooler on. -
$199.29
Genuine Volvo Truck Heat Exchanger. Steering Oil 21590718
States that below the price. .
Should not be a problem doing it yourself. 2 clamps for the hoses and 2 small bolts for the bracket to bolt it to the truck best I can see.
When it went out the system lost pressure which caused the jerk you felt.
Would be a good idea to change the fluid when you change the cooler.Stringb8n Thanks this. -
This is the one that was replaced on my truck. The clamps to the bracket are riveted on. Normally I'd replace things like this myself, but I noticed it during a post trip when dropping the truck off for another issue, so I can't really answer much about how it all went together. $800 for what I probably could have done in less than an hour, and they still didn't fill the power steering after it was done. Volvo of Denver, my favorite place ever...Stringb8n Thanks this. -
The 3 companies below are steering specialists so you might call and ask them. But I don't see anything about coolers on their websites.
Midwest Remanufacturing (pwrsteering.com)
Hydraulics - Pumps, Motors, Valves, Cylinders, PTOs - General Truck Parts
MR Steering Specialist – Remanufactured Power & Manual Steering Gear, Rack & Pinion
oil-cooler-brochure_individual-pages.pdf (haydenauto.com) -
I did it. Replaced the cooler. Someone who knows what they're doing and has all the tools right there should be able to knock it out in maybe an hour to an hour and a half. Of course this is assuming the hoses are connected together and bypassing the cooler as mine was when I went to replace it.
I took the rivets out of the bracket and used M5 bolts with washers, lock washer and a nut. Tried rivets to re-attach but had the wrong ones and the face of the rivet was way too much bigger than the original stuff. Even Volvo doesn't know the measurements of the rivet, yet they have a part number for the rivet. I wasn't going to drive all the way back to Volvo to get the rivets, when the guy in parts who sold me the heat exchanger said it was the entire kit they had. It wasn't, it was the cooler itself. No new clamps, no new bracket, no new rivets.
Would I do it again myself? Hell no.
