Power Steering issues
Discussion in 'Questions From New Drivers' started by rpierce8206, Sep 20, 2016.
  1. rpierce8206
    rpierce8206 Bobtail Member
    I've got an 07 pete with the c15 acert. My power steering has me baffled. It doesn't work worth a crap running down the road, but works fine at low rpm/idle. Fluid level is good. No foam in the reservoir.
    Any advice is greatly appreciated.
  3. AModelCat
    160,906
    Does it act up when driving slow but with high engine RPM's? Do you have a filter in the reservoir and has it been changed? I'm thinking if its acting up at high RPM's that maybe you're cavitating the pump with a restricted filter or line on the pump inlet.
    BUMBACLADWAR Thanks this.
  4. BoostedTeg
    BoostedTeg Road Train Member
    1,822
    3,301
    Jun 2, 2008
    Boise ID
    Replace the filter
    Dave_in_AZ Thanks this.
  5. siphertank
    siphertank Bobtail Member
    5
    Feb 7, 2017
    hello everyone I'm mechanic that specializes in power. ask away!!!!
