power window conversion
Discussion in 'Kenworth Forum' started by R-Dawg, Dec 9, 2015.
  1. R-Dawg
    R-Dawg Bobtail Member
    Has anyone here converted a KW with manual windows over to a power set up?
  3. cptdragn
    cptdragn Light Load Member
    63
    28
    Jan 4, 2014
    South Ala
    Interested in this as well
  4. DaveLV
    DaveLV Light Load Member
    182
    261
    Sep 18, 2015
    Yep in a 92 w9. Used donor doors that already had power windows in it. The right side was already power. If that is the case you can piggy back off the circuit or wire in a new one. Fairly simple to do regulator just needs a fused power supply switch and ground. Putting a power regulator in is a PITA. Mine had upholstered panel then steel inner panel. Found a door that had working parts and glass an I was in business. Time saved was money saved.
