Power window issue
Discussion in 'Freightliner Forum' started by nikmirbre, Apr 10, 2014.
  1. nikmirbre
    nikmirbre Road Train Member
    5,429
    9,794
    Jul 27, 2011
    High Point NC
    Was backing up so i rolled driver side window down(power). Would not go back up….after fooling with it for an hour I rigged it to where it would stay up and so its been like that a day or so. I look inside and the window is still on the track. I hear the motor and it sounds the seem and everything.
    It seems like whatever is suppose to take the window up doesn't do it. There is a metal rod that on the passenger side that the metal is attached to the little clip in the middle of the window. But, its not on the driver side.
    I looked online and it seems that piece is called the regulator. What exactly does the regulator do? Ive been looking but can't find what its purpose is.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    remove trim (held with many torx bolts) and look inside, sounds like bad cabel
  4. nikmirbre
    5,429
    9,794
    Jul 27, 2011
    High Point NC
    Yea I removed the door panel. It looks like the metal clip on the bottom of the window with a rod going kinda on it it broken off the window, but I don't see how that makes it go up and down……On the passenger side I took that off as well to see, and the metal rod is connected to the clip on the bottom of the window so i guess that has something to do with it….
