Practice Tests
Discussion in 'Trucking Schools and CDL Training Forum' started by K9OTR, Sep 4, 2013.
  1. K9OTR
    K9OTR Light Load Member
    140
    82
    Sep 1, 2013
    Rochester, NY
    Not sure if this is the right place to post but I wanted to see if there was a consensus about the worth of practice tests. I've taken a few online one being the one here and they seem to be simply common sense I've gotten 100% on most of them never under a 95%. Are they fairly close to an actual test. I'm a little suspect as they seem too easy, or is the actual test not all that difficult?
    Thanks!
  3. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    I've never taken a practice test, everything in the state issued FMC/CDL (<---or whatever the book is called?) is in it. I renewed and took exam again 2 yrs ago. I can't think of an exact question, but they try to trick you with being overly cautious when instead it asks for the specific rule... example: you should follow a vehicle in front at a distance of 10x your truck length, 5x, 2,x or none of the above. <---the answer is none above. Get what I mean?
    95% I'm sure they are drilling you harder than state exam, you'll do fine! Tell us how you did when you take the test.
    Wish you luck!
  4. K9OTR
    140
    82
    Sep 1, 2013
    Rochester, NY
    I'm a ways out yet from taking the exam, I just printed the state manual today. I'll flip through it tonight and see what else will be necessary to proceed. I will definitely post back with the results.
    TheDude1969 Thanks this.
  5. Night Prowler
    Night Prowler Medium Load Member
    549
    275
    Aug 9, 2013
    Temple, Texas
    i would say read each question twice before answering. the tests here are about the same as the one c1 school qives but theese have a little more to them ( harder ) but if your getting 100 % and havent even studdied ? i just wish i were that smart. it took me hours to get that good. Truck on !
  6. Powder Joints
    7,949
    8,296
    Sep 25, 2007
    Rosamond, SoCal
    K9OTR Thanks this.
  7. K9OTR
    140
    82
    Sep 1, 2013
    Rochester, NY
    THanks for the heads up... I think I was lucky on the first couple didn't do as well on subsequent attempts, but not all that awful... I'll keep at it thanks!
