Heya good buddies, question here. I need a good source as my quality control so I am doing good pre and post trips that will keep me outa hot water with the manager...ah yea, and keep my truck running well too.
Obviousy noone has time to do the pretrip we learned in school or had to do fer our tests, so what is a good check list to do in the real world. When I start in the morning, it's dark out.
So, any help is appriciated.
Rubber Duckles out.
Practicle Pre and Post trips help!
Discussion in 'Questions From New Drivers' started by Rubber Duckles, Jun 13, 2009.
You're watchin' too many "Smokey & Bandit" movies. The "good buddie' lingo is long dead and gone.
As far as pre-trip, you need a flashlight, then check oil, coolant, belts, hoses, tires, lights, turn signals, wipers, fuel level, air lines, mud flaps, and brake linings. Then as you are pulling out, pull your trolley valve down to be sure you got brakes to the trailer. Bleed your tanks, even if you have an air dryer. All this takes about 10 minutes. If you drive the same truck everyday, you will probably be able to skip the oil check and fuel level. Always check for flat tires at the end of the day. You will kick yourself if you come in to work and have a flat that could have been repaired overnight. -
Do it just like you were taught in school. Part of the joy of this job is the monotony of doing the same thing over and over and over the same way, day in and day out from now to eternity. And... when you start skipping a check that is what is going to break, blow, fall apart or stop working in the worst possible place.
After checking the front end and under the hood these are some shortcuts.
If the trailer is hooked but not finished up and even if it is, unhook the lines check for moisture in the glad hands and corrosion in the plug.
Hook up the hoses and lights, turn the turn 4 ways on and push in the supply button while leaving the yellow one pulled, then go back and do the trailer, checking from the left front to the right, listen carefully for leaks at the back of the trailer, if you hear one try to find the source. The air suspension should be coming up at this time as well.
If no leaks, the tires are up and the lights working, you can then pull the trolley valve to check for service brake leakage and check the brake lights on the tractor and the trailer. The waist lights should flash bright and dim, not on and off with the 4 ways.
If the trailer is hooked, you can't check the brakes from hooking; if from backing under, the trailer backs away, the brakes are not working correctly, either from adjustment or usually from breakage. This needs attention, might be broken springs in the chambers, but more likely,something is wrong with the mechanicals that apply the brakes.
You can do a tug test to check the brakes, if they are barely noticeable, the brakes need fixing.
On the lights, make sure the ICC marker lights are working on the trailer.LostSoulCA and halfburn Thank this. -
Good Buddy says it all.
You always have time for what you deem important. Pretripping is the most important thing you can do. -
Ok, thanks for the responces. Firstly, calm down, the Good Buddy thing was a freakin joke.
Secondly, it doesn't appear you all really do all this EVERY DAY, so, I was hoping for real life situations. Oh well, have a good day good buddies. -
