Pre EGR 12.7 smokes and flutters
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Kendall427, Dec 18, 2018.
  1. Kendall427
    Kendall427 Bobtail Member
    31
    11
    Sep 25, 2014
    miami, fl
    I have a 12.7 with an intermittent problem. While traveling at slow constant rpm in one of the first four gear. The engine ocasionally will begin to smoke excessively and the engine will flutter. There is no check engine light, and then it just stops and the truck drives fine. It has been happening more and more, usually after I start the engine after sitting a couple hours and then begin driving. I’ve begun to notice that I can tell when it’s about to happen because the engine loses that “crisp” sound. The engine had an out of frame rebuild done about 20k miles ago. Everything except the crank, and cam were replaced
  3. Heavyd
    Heavyd Road Train Member
    7,773
    6,211
    Feb 4, 2009
    I would guess rotten fuel lines and it is sucking some air.
    Kendall427 Thanks this.
