Pre Heater Volvo D-12 Engine
Discussion in 'Volvo Forum' started by Brian's Transport, Nov 21, 2014.
  1. Brian's Transport
    Brian's Transport Bobtail Member
    5
    Hello, anyone ever use the pre heater for a 1995 gmc white/volvo with a d-12 engine? i seen some stuff on line turn the key to pre heat and release back to start and a light on dash comes on. When goes out start. Is this the case? Also I can see on the heater the long conection piece is split or broken. The metal part. This d-12 it's hard to find people to work on it. Volvo dosent even like to work on it and they made it. Thanks, Brian
  3. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    Sorry Brian I don't know about a D12.
    On my D16, you turn the key to RUN position and wait for the preglow light to turn off and then start the engine.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    D12C and later preheat is controlled with engine ECU and big relay, early D12 and D12A had preheating modul. It was just timer with temperature control. If coolant temperature was low and ambirnt air temperature was low too (not sure, 5 dgr c) heater was on for 20-30 sec.
    What part is broken? Can u post a picture.
    D12 and D12A engines are still on road, really good engine!
  5. bzinger
    bzinger Road Train Member
    16,607
    65,876
    Dec 10, 2014
    omaha , ne
    had a d16 with that pre heat system on it and was best cold weather starting engine iv ever had , never idled unless it got below -10 f and would always fire up in the morn ...somtimes sounded like it was gona blow up the first minute or so tho lol.
