Pre Pass device - Battery Question
Discussion in 'Ask An Owner Operator' started by US MARINE, Sep 2, 2012.
  1. US MARINE
    US MARINE Heavy Load Member
    823
    170
    Sep 15, 2011
    I can't get mine to work . I shelved it for a while and just re activated it . It don't seem to work . Can you change the battery ? I have the new style unit kinda oblong .
    Maybe a test to check it I don't see a reset or buttons you could push in to hold or anything
    Thanks
  3. Colorato
    Colorato Road Train Member
    1,336
    865
    Feb 22, 2011
    The OE battery is a type AA but it is soldered to the board.
  4. US MARINE
    823
    170
    Sep 15, 2011
    So you can't change it ?
  5. Colorato
    1,336
    865
    Feb 22, 2011
    If you can solder it I guess you could try. The case is riveted shut so you'll either have to drill them out or break it. I'd think since there set up this way you outta be able to exchange it but don't know.
    Id be sure that you don't void the warranty or some weird reg by tampering with it before I did anything.
  6. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,980
    Apr 4, 2007
    Simple enough.
    When it is not working, you contact IPASS and exchange it.
    armo, TRKRSHONEY and Colorato Thank this.
  7. Raiderfanatic
    Raiderfanatic Heavy Load Member
    814
    561
    Jul 18, 2010
    Hutchinson, KS
    Yep. Once it quits working you have to get it exchanged. Not supposed to try and replace battery.
    TRKRSHONEY Thanks this.
  8. Autocar
    Autocar Road Train Member
    3,167
    2,358
    Apr 28, 2012
    The Hot Rod Shop Oxford, AL
    Contact your Carrier's permit department and they will exchange your Pre-Pass unit, for you.
  9. US MARINE
    823
    170
    Sep 15, 2011
    Its my box , I am the permit dept .. Lol
  10. Autocar
    3,167
    2,358
    Apr 28, 2012
    We are talking about Pre-Pass, for the scales, not EZ Pass or I-Pass, for tolls, are we not?
  11. TRKRSHONEY
    TRKRSHONEY Heavy Load Member
    726
    420
    Apr 23, 2009
    Knoxville, TN
    Just call PrePass with your account number, etc. They will gladly overnight a new one to you, Hubby and I had ours replaced. When you get the new one, send the old one back, I would suggest insured w/ return receipt for proof that it was received!!
    58Skylane, aiwiron and US MARINE Thank this.
