Any one use pre pass? How do you like it? Is it worth it for one truck? I'm thinking in getting it
Pre pass
Discussion in 'Ask An Owner Operator' started by 7.3 cowboy, Oct 18, 2013.
Page 1 of 6
It's worth it, IF, it does what it's suppose to do, every time. It's no guarantee to get you thru a scale without stopping. Some states "time stamp" you when going thru the scale which can be a hassle concerning your log book, if you get checked. Some scales might have the system turned off when you approach, which means you get nothing or you enter the scale. But even getting a "pass" 50% of the time would be worth it.
aiwiron Thanks this. -
If you are getting hassled at weigh stations now, it won't get you much, the system comes up with the same codes as the coops do, and if your company is set to be inspected, you will draw even more scrutiny.
Some companies avoid it because of that very reason.
I had it with my first decent job, but haven't had one for years and I don't really miss it. The coops I get static weighed at don't have either weigh in motion or Pre-pass, almost everywhere else, I get the bypass lane even loaded.
It's not in the cards where I'm at now. -
I am not getting hassled. I just don't like stopping unless I have to. They said based on my score that ill only have to stop 5% of the time in the states ill run in. On the website it says there are no time stamps only the date when it was done
well they might not time stamp at a weigh station but they time stamp tolls
because how else would they catch the bad guys on Law and Orderscottied67 Thanks this. -
It depends on were you run, only about half of the scales I go by even have Pre-pass. I'm not getting checked at all at present, but there is nothing stopping you being pulled over away from the scale even if you run Pre-pass. Frankly, I am seeing more of that all of the time.
I was told the date thing, too, by the first company, but states not using Pre-pass are not bound by that agreement. -
I'.ve has it for about 9 mos., usually I'd drive pass 4 of 5 open scale houses. But July I visited every open scale.
I drove for Trans Am for 2 years
our CSA score was so bad DOT took away our prepass
but I never was inspected anywhere
so I am not sure DOT even really has a bad boy list
or more driver paranoia
to me a newer clean truck with a clean dashboard helps
but then again might all be the roll of the dice -
Newer truck, clean once in a while, stuff on the dash, sometimes, actually most of the time, makes no difference, in my experience, but a truck from the 'wrong' company has them pulling in just washed bobtails for the old once over, so, depending on where you are running, there are lists you don't want to be on.
Might only be certain places, but my home state has been called one of the bad ones by some. I never got red lighted in Iowa when I had Pre-pass, but got red lighted into closed scales in other states, so I have real life experience with that question.
Page 1 of 6
