Pre Planning avg MPH??
Discussion in 'Questions From New Drivers' started by slingblade07, Sep 16, 2008.
  1. slingblade07
    slingblade07 Light Load Member
    162
    27
    Sep 3, 2008
    Commerce, GA
    Wondering what everyone uses for there avg MPH when preplanning a trip, have heard anything between 50 and 60. I know a truck that is stuck at 62 cant plan on 50, so maybe that makes a big difference.
  3. Lilbit
    Lilbit Road Train Member
    16,583
    12,232
    Aug 4, 2008
    Let me check my logbook
    Even if you are governed at 62, you can get a pretty accurate estimate using 50 mph as your base for preplanning. My hubby's truck only gets to 64, and he uses 50 mph all the time, and that works quite well for him.
  4. slingblade07
    162
    27
    Sep 3, 2008
    Commerce, GA
    Sorry meant to say 60 not 50 when governed to 62. :biggrin_2552:
  5. Lilbit
    16,583
    12,232
    Aug 4, 2008
    That's ok, I've made plenty of oops like that before! 50 should be a good base for you to work from for preplanning no matter what your governed speed is.
  6. Minus...
    Minus... Light Load Member
    199
    19
    Jul 18, 2008
    Philly, PA...
    I would use 50mph...because more then likey the speed limit will be atleast 55...65 at the highest...so if your going 65...and planned for 50...then you shouldn't be late...being ahead of time lets you kinda relax...take breaks...i prefer to get to my reciever fast as possible...slow up maybe and take breaks when i'm close...either go drop off and get another load...or kinda chill out if i'm tired and wanna mess at the truck stop...but i'm still in school...so i'm only saying what i would do...
  7. socalborn
    socalborn Bobtail Member
    36
    Sep 22, 2006
    Lincoln, Nebraska for now
    Me, too. I'm finishing school (took my CDL road test today), and I have never gotten a straight answer. I live in Lincoln and went down to the Crete terminal to practice backing inbetween trailers. We went to the cafeteria and spoke with a couple of drivers afterward. They couldn't give me an answer. I've always been of the mind to get the load there ASAP because you don't know what might pop up along the way. Then there have been drivers that have told me that they drive as close to eight hours a day as possible so that their 60/7 doesn't run out and leave them sitting somewhere they don't want to be.
    Does this just all amount to hoping that your load offers give you enough time? I have heard how pushy dispatchers can get. I would hope the line between reality and a 'hopeful' result would be clear.
  8. 25(2)+2
    18,751
    45,562
    Sep 18, 2006
    the road less travelled
    When you get some experience,meaning several years, you will know about how long something should take, until then, if you are running local two lane roads, figure at least 10 under the speed limit as an average, It might be 40 to 45. Interstates should be able to do at least 50 unless the weather is bad.
    You need to ask about places to break when starting out, or you run the risk of being stranded on the road out of hours with no place to park.
  9. alabama grappler
    alabama grappler Bobtail Member
    43
    6
    Sep 16, 2008
    Decatur, AL
    If my truck only does 60 MPH... I plan on around 650 for that day.
    It all depends on how fast my truck goes and what states (cause of the speed limit) that I go through. I run loose leaf so that helps me keep a tight log. And it is ALL legal (atleast on paper...lol). I do make sure my fuel stops are very close to the time I actually fueled. That is a time stamp for DOT to check your logs.
  10. slingblade07
    162
    27
    Sep 3, 2008
    Commerce, GA
    So if your governed at 60 you dont think anyone will raise an eyebrow at going 650 in an 11hr day?
  11. alabama grappler
    43
    6
    Sep 16, 2008
    Decatur, AL
    The only people that knows what it is governed at is your company... haven't met up with a DOT officer yet that stuck a computer to the truck.
    Now your company might want you to log under a certain MPH, some companies check it with the qual com. Ask the company you drive for about what MPH to log at? THEY WILL NOT TELL YOU TO CHEAT... but shaving 5 mins off here and there brings your MPH up.
    EX. if you leave 5 mins before the hour (log on the hour)..... and stop at 20 mins after the hour (log on the 1/4)... that gives you 10 extra mins of driving that day. Which inturns... if logging while driving... raises your MPH
