Pre-Trip Test - Where are the cross ribs?
Discussion in 'Questions From New Drivers' started by NewNashGuy, Dec 9, 2011.
  1. NewNashGuy
    NewNashGuy Road Train Member
    1,616
    752
    Jul 27, 2011
    US and Canada
    Hello, I tried searching but couldn't find this answer. I am doing my final pretrip test today at school and we have to mention the cross ribs on the trailer. Are the cross ribs on the bottom of the trailer for added support? I need to be able to point to it. Thanks :)
  3. TennMan
    TennMan Road Train Member
    7,866
    9,658
    Sep 21, 2011
    Hazzard County Jail !!!!!
    They should've taught you that in school........................... however i'll try and help. They are the supports that run from the drivers side to the passenger side under the total lenghth of the trailer they are spaced about 1 foot apart and look like joists would in the floor of a house. Hope this helps.
  4. NewNashGuy
    1,616
    752
    Jul 27, 2011
    US and Canada
    Thx and not this was not mentioned. Understandable since a lot of students interrupt the teacher with off topic stories so he probably forgot to mention it.
  5. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    When in doubt point it out! (and then give it a name)
    Break down the truck in sections or categories and hopefully that will help you out a little. Exhaust, Motor and components, Brakes, Air, Tires, Lights, Body etc... Everything on that truck that isn't cosmetic should pretty much be on your pre-trip. Unless a Fender is cracked up good or there is a hole in something or something falling off. Otherwise all mechanical and structural parts and pieces including nuts and bolts.
  6. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    I'm guessing here now but I would say it's the members that are bolted to the frame that secures the truck beams together. But if I were you I'd search on line because there's tons of information on doing pre-trip inspections. Even a lot with diagrams that you can download. If all fails you can point to it during the inspecting and say "this cross member is secure and free from cracks,rips,rust, and missing bolts".
  7. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    There is a different name for many parts, depending on your location in the world. I always heard them refered to as Cross Members.
    Also, the IL inspector did not want to hear, "not cracked, bent, broken". I would assume because he was sick of hearing that for every part in the truck.
    His preferred phrase was, "in good condition". Which I actually prefer as well...
    Mikeeee
  8. Joescheppae Q
    Joescheppae Q Medium Load Member
    350
    158
    Aug 20, 2011
    Ply Mtg, PA
    "cross members in good condition" sounds right.
  9. Pmracing
    6,354
    3,178
    Jan 28, 2011
    Unlike when I picked up, or tried to pick up, the preloaded trailer with 4 crushed members that support the dollies, and 3 flat tandem tires!
    Mikeeee
  10. Bright Lights
    Bright Lights Bobtail Member
    NW Ohio
    Cross members are not cracked or bent and none are missing.
  11. Sequoia
    Sequoia Road Train Member
    2,692
    1,794
    Dec 4, 2010
    Tampa Bay, FL
    "(item) is not cracked, bent, broken or missing and is in good operating condition."
    Even if you draw a blank on the name of the item, pointing to it and mention ^^^ all that should suffice.
    I call cross ribs 'cross members'.
