Predator 3500
Discussion in 'Ask An Owner Operator' started by Dino soar, Nov 7, 2021.
  1. Dino soar
    Dino soar Road Train Member
    4,791
    26,878
    Dec 8, 2017
    Just a couple questions about my predator.
    It starts and runs excellent. It's running my 1500 watt space heater on eco mode with no problem.
    I'm having possibly two issues. The first issue is the knob you turn for start and run seems like it has a little play like it's a little sloppy. It works but it just seems like it should be tighter than that.
    The second thing is that the display does not tell me anyting. When I first put it on eco mode it'll say like 122 with the space heater plugged in but then it's screen just goes blank again.
    Seems like everything else is working like it should. Should I return this and get another unit or should I continue as I am?
    I'm 2 oil changes in and it seems like it runs well.
  3. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,471
    Nov 7, 2007
    Possum Booger, Alabama
    Display panels are #### quality. I opened one up and found a piece of fine copper wire shorting out the IC pins.
    The knob has a small screw that retains it down in the hole. It needs tightened if it hasn't already fell out.
    Rideandrepair and Dino soar Thank this.
  4. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,032
    Dec 31, 2010
    Washington, PA
    The knob on the display one I looked at was also sloppy. Figured it was just from everyone messing with it.
    Dino soar and Rideandrepair Thank this.
